Throttle body Problem
Old Apr 22, 2001 | 11:48 PM
cobra99's Avatar
Red face Throttle body Problem
I have a 2000 Lightning with a single bore throttle body. Can't get it to idle down. It seems like it binds when closing and won't allow it to return to around 650 rpms. It seems to stick around 875-1200 rpms. I played with the tps and the idle set screw. I put a allen head bolt so I can adjust it easy instead of grabing it with pliers. I'm gonna take it apart tomorrow night and to make it worse my check engine soon light is on. Only thing I installed was JDM 90 Mass air meter, JDM chip, and JL ram air, Does any one have any sugestions? Has anyone run into this?> Thanks.
2000 F-150 4x4 Super Cab Oxford White Short box. Piaa Head light clear Front turn signals bulbs,5.4L,3.55ls, Superchip,Borla exhaust, K+N.. More to come.
2000 SVT WHITE LIGHTNING...
JDM PROGRAM chip
90 MM Mass Air Meter
Single Bore Throttle body
JDM Driveshaft,12" Cone Filter,2001 Headlights,tailights,turn signals, and center stop lamp.
Piaa head lamp bulbs
Precision Power amp PC4400
Pioneer 6x8 #TS-A6865 3-ways
Pioneer DEH-9200 Deck with Pioneer 6 disk. bassinni cat pipes and cat back.
Perma-tech sprayed in bedliner.
drop shackles
JL Ram Air Kit
JL Drive shaft loop
Lo-tek 3 guage pod for pillar.
code alarm with auto start.
Old Apr 22, 2001 | 11:52 PM
Spiro99SVT's Avatar
Post
Start with the obvious. Remove chip and reset the battery for another test. Simply repeat the procedure for each mod, and try to pinpoint problem..or cause of the HIGH IDLE. Hope this helps
Spiro-
12.373 @ 110.15
Best 60' 1.76
@ 4700 without the Go-Go juice
11.94 @ 115.31 with the Go-Go juice @ 4700 lbs.
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Old Apr 23, 2001 | 12:38 AM
super dave's Avatar
Post
Sounds like a vacuum leak somehwere? Check to make sure your small hoses are in good shape and connected.
Old Apr 23, 2001 | 08:02 AM
cobra99's Avatar
Post
I went through the Vaccum lines. I also checked the boot and mass air meter by putting my hand over the meter and restricted the air and stalled the engine. Did the battery deal too. I might go back to original and replace one part at a time.
Old Apr 23, 2001 | 08:09 AM
PFA's Avatar
PFA
Post
If the blade is binding when closing, it may be out of alignment or closing too far. You can back the four screws out a bit and try snapping it shut a couple of times. This should align it back up. With the blade held closed tighten the screws back up.
Have you contacted your supplier about this?
Hope this helps.
PFA
2001 WHITE LIGHTNIN'
2001 Windstar Sport
SOLD-with $4K from FORD!
'99 WHITE LIGHTNIN'
#0873--1 of 866--
