Replacement Pistons?
Old Apr 16, 2001 | 08:59 PM
2 cam sam's Avatar
Post Replacement Pistons?
Howdy fellow modular enthusiats! I just wanted to see if any of you have had to get get your motors rebuilt with new pistons? Did you use stock replacements? How much did you pay? Is there a Ford dealer who will give better deals on part number 6108 std bore Lighting piston? Any replys will be much apprecciated! Thank you!
Old Apr 17, 2001 | 06:48 PM
2 cam sam's Avatar
Post
Somebody has to have blown up a motor or 2 on this board. Any replies would be helpful.
Old Apr 17, 2001 | 07:52 PM
Hurricane Larry's Avatar
Post
2 cam sam,
Did you try http://www.fordpartsonline.com/ or http://www.buyfordmotorsport.com/ (for $380 a set)?
Several have ruined motors, but to the best of my knowledge have all been repaired under warranty.
Old Apr 17, 2001 | 10:40 PM
Ruslow's Avatar
Post
Might be checking into that if time allows since I trashed the valve in mine.Stan
Its only money!!!!!!
Old Apr 17, 2001 | 10:43 PM
StruckBy99's Avatar
Post
Try Sean Hyland Motorsport for pistons. They can custom make pistons for modulars in any compression ratio. 9.5:1's cost $105 a piece for the 5.4 in the lightning. www.seanhylandmotorsport.com
Black '99 #398 of 4000
SHM mass air/filter, SHM chip, Level 10 shift kit and converter.
13.71 @ 98.2 mph (stock)
13.34 @ 102 mph (chip/mass air)
Converter/shift kit to be tested soon
[This message has been edited by StruckBy99 (edited 04-17-2001).]
Old Apr 17, 2001 | 11:02 PM
Post
Let's see, $47.50 each from Ford for OEM pistons, or pay $108 each to the over hyped losers at SHM. This could be a tough choice.
Old Apr 21, 2001 | 10:43 AM
StruckBy99's Avatar
Wink
Hurricane:
"Over hyped losers"!?!
For $105ea. you can get any compression ratio you want. If stock compression is what you want, get stock pistons. If your building your motor up, $105 for custom pistons is not a bad price.
