Problems with an 01 motor in a 99
Old Apr 17, 2001 | 02:48 PM
action 911's Avatar
Unhappy Problems with an 01 motor in a 99
I need alittle help here. I have an 01 motor in my 99. I have the lower intake manifold and blower. I have Sal's street chip/Pro-M/ Sal's lower pulley. I have ping at tip in. Also at WFO. I put the stock Mass air back on (80mm) and it still pings (slight) I was thinking about trying the Pro-M Remote Optimizer. It connects in-line with the mass air meter. It has adjustments for air flow, for rich/lean by turning the idle/high flow *****. Also, I have had Sal to re-program the chip twice now, and it still pings. What do you think I should do? I don't want to run race gas, or a mix. I just want yo drive up to the pump and go.
HJ
Old Apr 17, 2001 | 02:59 PM
1BADTK's Avatar
Post
Optimizer can not be run full time, only for calabration of MAF. If you do add a octane boost does it stop the ping?
Old Apr 17, 2001 | 03:12 PM
LightningTuner's Avatar
Post
Herb, when you put the stock MAF back on, did it still ping at WOT or just on tip in? Sounds like you may need a little more fuel. The 01 intake may require some additional tip in fuel adder on the 99-00 calibration due to it's different airflow. We can take care of it for you, I just need some more info on when it does it. You can E-mail me if you like.
SAL - TEAM PSP
Old Apr 17, 2001 | 03:22 PM
mikey88's Avatar
Post
Sal, what is your phone number and/or email?
OO L Black, Superchip R9, Airaid FIPK and Tonneau cover: 1999 F-150 Lariat SC 2 WD, White/Silver, 5.4L, 3.55LS, K & N FIPK, Superchip, underdrive pulley set, Flowmaster dual chamber one in and duels out, six disc CD changer, towing package and captain chairs
Old Apr 17, 2001 | 04:50 PM
2nd Bolt's Avatar
Post
Herb, You had no pinging issues at Dyno day a few weeks ago but it looks like you added a pulley since then. Could this be the problem? Good Luck!
Jeff
Silver 00
3/4 Drop
Snuglid
Stongard
JL ram-air
Oval-Bore T/B
01 Meter
JDM chip
Old Apr 17, 2001 | 11:23 PM
Bad as L's Avatar
Post
Herb's workin right now so I'll go ahead and jump in. I rode in the truck last night and when it is cool it does'nt seem to have a ping problem, also the ping isn't severe but he does'nt want any at all. Also Jeff you are right, this little problem didn't start until the pulley went on, and I can tell you right now he isn't about to take the pulley off :-). He ordered a cooler (160) thermostat for it, just because it does run better when its cool (less ping).
Also I only rode in the truck when it had the stock MAF on it so I can't comment on what is happening when he bolts on the PRO-M.
Dale
Old Apr 19, 2001 | 12:18 AM
2nd Bolt's Avatar
Post
Dale, You didnt experience this problem when you put your pulley on did you? I hope you guys get it figured out.
Jeff
Old Apr 19, 2001 | 01:50 AM
Bad as L's Avatar
Post
Jeff
I think the problem with Herbs combo is the Pro-M, the one he has is very aggresive for lack of a better term and it would have to be put on a dyno and a chip made for it to cure the problem. Herb is dropping the Pro-M and going with the 90mm MAF and a new street Performance program from Sal.
I havent had any detonation problems with my truck, but I run a 50/50 mix of 100/92 most of the time cause I don't drive it that much and I always like it runnin good if you know what I mean :-).
I had long tubes and a full exhaust put on by a small local performance shop today. Haven't got to much time on it yet,but I can tell it runs better and sounds much better.
Dale
Old Apr 19, 2001 | 01:59 AM
Bad as L's Avatar
Post
Hi Jeff
One more thing, I didnt make this very clear in my last post. I run a RACE program almost all the time, that is why the mixed fuel. If a run on the street perf. setting there is no detonation with the pulley, but for now I am also running a stock MAF. But that could change at any moment :-).
Dale
Old Apr 19, 2001 | 03:19 PM
action 911's Avatar
Wink
Sal,
THANKS for the help!
Myself or Dale will let you know what he comes up with, far as numbers go on the long tubes. I talked to Dale over the phone last night and he sounds pumped about the tubes.
Herb ;-)
Old Apr 19, 2001 | 06:41 PM
2nd Bolt's Avatar
Post
Dale, Glad to hear you finally got those long tubes on! I changed my plugs today and wanted to thank you for the heads up on that swivel 7mm, took a little over 2 hours. Hope to see you guys on the 29th!!!!
