Ford cam bolt kit part number?
Does anyone know what the part number is for the Ford cam bolt kit? Is this something I can put in my self and then take the truck to the dealer to get alligned?
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
John
93 Teal Cobra #4656
Call me an idiot but I don't know what a cam bolt or washer does. Could someone explain it to me. And what is wrong with the factory ones. thanks
'01 Lightning, bran spankin' new
'77 Harley Sporster, 74inch stroker motor w/all the trimings.
'96 Honda CBR 600, Jet kit, M4 pipe (Kills me to own Jap Crap, but it sure is fun)
you need the cam bolt kit to align the truck.
it comes stock with a alignment "plate", which puts the alignment in the ballpark..
but if you need to realign your truck, you'll need the cam kits.
you'll need the kits when you get your clunk fixed.
brooks
brooks
Don't get Ford cam bolts......Way to pricey!!!! Napa is good or any quality alignment shop should have them.
01L,Lowered, Black,Downey SST,Straight Pipes,Chipped........ Toy: 91 Heritage Softtail Classic/Lowered
My 99 L has what looks like a cam bolt in the upper/rear passengerside a-arm. Is this from the factory? I have the alignment problem too. They tried fixing it with the toothed washer but it still moved with-in 100 miles. Also should I try to get the washers that take up space in the lower control arm or will the cam bolts work alone? Thanks Josh
99 L 312 OF 4000
Pro-M, Bassani headers and cat pipes, Borla cat-back, Lentech valvebody, Superchip Flipchip,PSP lower pulley, BFG Drag Radials 12.xx
SEE YOU @ NMRA COLUMBUS
99 L 312 OF 4000
Some of the '99s had full cam bolt sets from the factory, some had just two, most had none after the bean counters decided that anyone rich enough to own a Lightning could afford to buy their own kits. You can get the specialty products http://specprod.com/ kit (p/n 87385) a lot cheaper than the Ford kit. And you are right, the star washer "fix" doesn't, you need to get a set of Herb Jackson's spacers before he runs out.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
13.39 @ 102.5
gmvye@pacbell.net
