Blown Motor
Old Apr 17, 2001 | 10:38 PM
Ruslow's Avatar
Angry Blown Motor
Well,not exactly,but in my running at Big Bend I went lean at 150,thought I blew the hd gaskets but they are intact.What I did was stretch 5 of the intake valves so they would not close on the seat.So now I have to replace them.OH well thats racing!!!!
PS can we say extrude hone and bigger valves or maybe new hds?Then extrude hone.Stan
Old Apr 17, 2001 | 11:30 PM
thepawn's Avatar
Post
That sux. You just got the cage up too.
Dan
Old Apr 17, 2001 | 11:41 PM
DreaminAboutL's Avatar
Question
How the heck do intake valves get STRETCHED?
Old Apr 18, 2001 | 12:31 AM
My2003Lightning's Avatar
Post
Stan,
Good to see your back in Ark. or somewhere. Tell us about Buttonwillow! I saw your pics on SpikeEngineering's web-site. When are you going back to Hallett? I have the video setup, etc. for the run.
Yes, explain about your intake valves being stretched! Sounds like Rogers, Ark. is the Area 51 for Lightnings!
Take care, Stan and keep it between the ditches!
Ronald....
Old Apr 18, 2001 | 02:26 AM
Bolt's Avatar
Post
I have sucked a few valves in my time but never streched em..
Airaid, PSP Pulley, Brembo's, Aluminum DS, 4:10's.
Old Apr 18, 2001 | 02:33 AM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Post
Cracked a valve spring? Maybe you ought to check out http://www.Coatesengine.com/ for a new set of heads. Only $15k. But they are worth it...
Old Apr 18, 2001 | 07:00 AM
WHAT04's Avatar
Post
Hey Bolt, that's far more info than I needed to know.
Old Apr 18, 2001 | 08:35 AM
Ruslow's Avatar
Post
The only way that I know of or can think of is that when the valve is red hot and with 10+ psi of boost on the back side on a valve almost 2" in dia.You have a 20# force trying to open the valve so it is like pulling on a hot piece of steel.When I build blower motors I have to take into account the valve size and boost to work up spring psi.That is the only way I can figure it did it.Stan
Old Apr 18, 2001 | 10:05 AM
Silver-Bolt's Avatar
Post
Stan,
It sounds like it's time for titanium valves. Handle the heat and pressure much better. The light weight is an added bonus.
2000 Silver Lightning 13.82 (stock)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
Snug-Lid
In the works:
Level 10 converter
4-Link
Old Apr 18, 2001 | 10:32 AM
Jay Lincoln's Avatar
Post
Ruslow, what kind of RPM were you pulling? We had the same problem at Boneville one year. The valve springs weren't strong enough and allowed the valves to float. This kept the valves bouncing instead of seating properly. They couldn't transfer heat out to the seat and subsequently would "tulip". Let me guess, was it the intakes?
Red 00"
Pro-M mass air
Swanson Chip
Aluminum Driveshaft
Jay Lincoln Homemade Traction Bars
*******'s bed cover
