Anyone with lighted logos or general electrical knowledge?
Old Apr 17, 2001 | 04:43 PM
John893's Avatar
Post Anyone with lighted logos or general electrical knowledge?
I have the lighted logos installed on my truck. I have them taped into the marker lights. How hard would it be to hook the logos up to a switch so I could turn them on and off as I please?
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Apr 17, 2001 | 05:16 PM
Silver_2000's Avatar
Post
John
Check out my web page - I took some pictures when I intsalled mine. They are wired to the fog light circuit so I can turn them off and on with the fogs
Doug
Picked up Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !! Best Run 13.025
Silver_2000@SVTLightnings.com
www.SVTLightnings.com
2000 Lightning, FMS 3.73 gears ( Expensive ), PSP 4 Way Chip, PSP Intake, Valentine 1, Snuglid, Bedrug, Lighted Ford Logos, Superchip R9, and 3m Panther Black nickel tint, Clear corners., Boston Acoustics 5x7s and Components, Alpine v12 5 channel Amp and JL Sub, Chrome SVT Rims and G Force R1a Autocross Tires, .
Link to my profile because the UBB doesnt support semicolons any more
Old Apr 17, 2001 | 05:21 PM
curmudgen's Avatar
Talking
You have 2 conditions to discuss. Turn them on & off with the marker light ON: just route the wire you have tied to the marker light, thru a switch. You could also use the voltage from the marker lights to turn a solenoid on and off with the same new switch.
If you want to turn your new lights on without any other lights on, then you will need to get voltage to them via a switch or the aforementioned switch and solenoid similar to the kit you get with aftermarket fog lights. You might want some help with the second options.
Red 99
Old Apr 17, 2001 | 08:23 PM
clonetek's Avatar
Post
i wired my logo to a switch..
install light, connect transformer, run wires inside cab, ground the negative wire,
connect the positive wire to one side of a small switch (raidoshack)
connect another piece of wire to the other side of the switch & tap into the fuse box for power.
there is a small hole in the e-brake bracket that i used to mount the switch. its hidden under the dash, but i can reach down & flick it on with no problem.
you can see just barely see the hole in the top left corner of this picture.
i used fuse taps to get power for my radar detector & logo.
you can find them at raidoshack and auto stores.
sorry for the blurry pics.
hope this helps
brooks
'00 silver "L"
member NLOC #496
my zing albums - _-click here-_
clonetek@jam.rr.com
