Disconnect water pump?
Old Apr 16, 2001 | 10:30 PM
alphadoggy's Avatar
Question Disconnect water pump?
As I have previously mentioned, I have only added plain water to my i/c reservoir since it began leaking last fall. Lately, however, the leak has gotten much worse. I have been refilling the reservoir every 100 miles or so, but today I popped the hood and discovered that the reservoir was bone dry, after only 50 miles. I am concerned that this just may be too much for the motor to handle, and I think I should disconnect the pump. Can anyone tell me how to do this, hopefully with some pics?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old Apr 17, 2001 | 08:43 AM
JohnnyLightning's Avatar
Post
I can't show you any pictures,however if you look under the front of your truck on the driver side you'll see the pump with the connector hooked to it just squeeze the connector and pull off! thats it! or you can do what i did put the SMALL bottle of bars leak in the resivior and fill with water run for 3 days drain back out and fill with anti freese. mine hasn't leaked since..... JL
93 cobra 10.90@127.00
99 lightning (black)
E.T. 12.06
best mph 112
60 ft. 1.65
(All Throttle No Bottle!)
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
Test Converter!
DiabloSport Dist.!
(KEEP IT BETWEEN THE LINES!)
_ _ _ _ _ _ _ _ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:JohnnylightningPerf.com
svtperformance.com
diablosport.com
Old Apr 18, 2001 | 12:25 AM
alphadoggy's Avatar
Post
Thanks, JL, maybe I'll give the bars leak a shot.
Addendum: mentioned the bars leak to my mechanic this a.m. He said he had had much more success with BG cooling system sealant, gave me a can to try. If it works, will report.
[This message has been edited by alphadoggy (edited 04-17-2001).]
