Help transmission problems????
Old Apr 9, 2001 | 06:50 PM
mikey88's Avatar
Post Help transmission problems????
Today my 00 L will not shift out of 1st gear under WOT and hard acceleration. Any suggestions? Could it be the chip? I have the R9. Even when it shifts under normal driving it's not shifting right. I'm going to remove the chip and try than. Thanks in advance
OO L Black, Superchip R9, Airaid FIPK and Tonneau cover 1999 F-150 Lariat SC 2 WD, White/Silver, 5.4L, 3.55LS, K & N FIPK, Superchip, underdrive pulley set, Flowmaster dual chamber one in and duels out, six disc CD changer, towing package and captain chairs
Old Apr 9, 2001 | 11:04 PM
wrightlightning's Avatar
Unhappy
Well, good luck to you. I hope it is the chip, but that sounds similar to what I experienced right before my SECOND tranny went out...with 100 miles on it.
Black '00
#2216
[This message has been edited by wrightlightning (edited 04-09-2001).]
Old Apr 10, 2001 | 01:00 AM
alphadoggy's Avatar
Red face
My tranny is also balking on the 1-2 shift under wot. We think it is a bad solenoid, but won't know until I take it to the dealer on the 23rd (if it lasts that long). I think the solenoid is the most likely culprit; I would check it first.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old Apr 10, 2001 | 10:56 AM
mikey88's Avatar
Post
Well, I took it to the dealer this morning and I am waiting to hear what the problem is. It still did the exact same thing without the chip. I'll post a result of their finding when I hear.
Old Apr 11, 2001 | 11:08 AM
mikey88's Avatar
Post
Got a call from the dealer just now and he said 2nd gear is "shredded". He then stated I'm gonna help you out this time but if you put that chip back in it will void your warranty. I took it out, but I guess he could see where the tape was. Now for the knockout blow, he states, "When you get the survey from ford, give me complete satisfaction because very good satisfaction is not good enough". Can you believe that sh$t?
OO L Black, Superchip R9, Airaid FIPK and Tonneau cover: 1999 F-150 Lariat SC 2 WD, White/Silver, 5.4L, 3.55LS, K & N FIPK, Superchip, underdrive pulley set, Flowmaster dual chamber one in and duels out, six disc CD changer, towing package and captain chairs
Old Apr 11, 2001 | 06:26 PM
RTKILLA's Avatar
Post
I just dropped mine off at the dealer for the almost same problem, mine would shift but only after the truck reved all the way up past 5000, at about 1/4 throttle. Thats barely moving the damn truck. There putting in a new trans this week. Its most likely not the chip. I had an R9 before and then I put a new 90 with the PSP 4 way program and after a week the trans happend to me. So I took the chips out and put the stock mm on and resetted the CPU and sure enough its still doing it. My tech whos a fellow racer, said that it sounds like it might be some type of piston in the valve body sticking. something like that.
Take the truck in, but reset the CPU first.
Built 5/4/99
# 917 of 4000
2001 ET: With the barometer below 30 and the temp at 35 degrees and no traction at all:
Reaction: .658
60 foot, 2.433 on street tires
E.T.: 13.59
MPH: 108.23 !!!!!!
When the tailgate drops, the bullsh*t stops.
MY ZING ALBUM: http://www.zing.com/album/?id=4293132307
Old Apr 11, 2001 | 06:29 PM
Holeshot's Avatar
Post
Rtkilla,
you're reseting the ECU by disconnecting the battery overnight?
00' Lightning/ Black
99' Lightning/ Red
94' Lightning/ Red
96' Cobra Convert/ Red
98' Yamaha R1
R6 Race bikes
Old Apr 11, 2001 | 11:23 PM
Post
mikey88,
That is what happened to my FIRST tranny. Second gear was gone. The dealership made me buy another computer b-4 they would even work on it (as I previously had a chip in it). They did replace it, after giving me grief over the chip. I have not gotten a survey yet, though. Someone called and talked to my wife and she told them they did not want to talk to me (since the second tranny was out 2 days after they put it in).
Also, just as an fyi, just disconnecting the battery and draining the memory, the "chip code"--p0605 or something--is still there!
Black '00
#2216
Old Apr 11, 2001 | 11:45 PM
HIGH ROLLER's Avatar
Unhappy
mikey88,
This is just what i went through a few weeks ago,i would bet that they will give you a new valve body kit and replace the clutches!
Keep us posted!!!
Matt
Old Mar 23, 2012 | 07:03 PM
spitfirekev33's Avatar
i have a 1999 and it seems to shift hard into 2nd gear . every thing else works great..dose anyone know what the problem might be ??????????? ahhhhh
Old Mar 24, 2012 | 06:15 PM
FireGuy's Avatar
Thanks for digging up an eleven year old thread, it proves that you were at least searching for a solution before posting.
Most likely, your second gear clutches and sprague are toast and your tranny is due for a trip to the rebuilder, sorry but I have seen this many times before.
Mine was rebuilt by a local transmission shop for around $1700 with upgraded parts. Good luck with yours.
Old Mar 25, 2012 | 10:42 AM
6Lstrokin's Avatar
I've been trying to find a place to buy upgraded clutch kit for my lightning build then a local shop is going to rebuild mine. Any recommendations of a place to call?
Old Mar 27, 2012 | 11:33 AM
BlueOvalBolt's Avatar
Did you buy your truck used? If so, the previous owner could have put a valve body (FTVB, Punisher, LFP, etc.) in to shift harder which wouldn't be a bad thing.
