Herbs washers
These are apparently used to fix some front end bug, did a search under herbs washers, but didn't get a lot of specific info. Can anyone explain what these are,where to get, and exactly what the bug is that they fix.
01L lowered, black,Downey SST,Straight Pipes,Chipped,Wet Oalke Covers... Toy: 91 Heritage Softtail Classic/lowered
When the blower is shrieken' the bulls**ters are freakin'....
The lower A-arms tend to move relative to the bolt. Herbs washers hold them in place.
See this thread for pictures...
https://www.f150online.com/f150board...ML/007693.html
Ford don't really have a fix.
In a nutshell, the holes in the lower control arm oval-shaped, not round. Therefore, it causes the bolt to move back and forth at full lock or with the wheels turned going into a driveway. Herb's inserts fill the oval and keep the bolt from moving. Ford tried a star washer, no good. IMHO, these are THE fix, period. Of course you could weld the existing washer too but a majority of dealers will not do that.
Here's a pic of where the washers go.
Try a search on front end clunk. There is also info in the FAQ.
[This message has been edited by Speedin Bob (edited 04-06-2001).]
Put my check in the mail today. I can attest that the star washer fix doesn't. Front tires are wearing unevenly, ready to replace them, but not til I get Herb's gizmos, no use ruining another pair. Wonder if my dealer will install them under warantee?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
13.39 @ 102.5
gmvye@pacbell.net
Alphadoggy the dealer won't do it for you because it's not a Ford part. Do it youself! Very easy to do.
HJ
HJ
action 911:
I sent you a check about a week ago, have you received it yet? Thanks Bill
Bill
'00 white lightning-#2030 of 4966-4/6/00 thursday
muth mirrors,door key pad mod,fog light mod,
clear corners, super white; headlights,corners,fogs,
trenz billet upper and lower grills, billet 3rd brake light cover,
Bedrug, harley davidson tonneau cover,
JDM flip chip, JDM lower pulley, 90mm mass air, JDM tranny mod,
JDM 5"aluminum driveshaft,
J.L. stage 2 ram air kit
BellTech 3/4 lowering kit
2001 tails installed
20" chrome lightning wheels on order
more to come....
my zing albums-_-click here-_
'00 harley davidson FLSTC tons of custom parts..
'99.5 nissan pathfinder le-STILLEN EQUIPPED
'88 toyota show truck(TONKA)
'91 toyota mr2 turbo (to many mods to list)
'00 yamaha banshee(toomy race kit/chrome pipes)
Bill
more to come....
Herb, So I guess if you use your washers on the drivers side, install the front and back cam bolts on top on both sides (then all the adjustment can be done from the top), then this should take care of all the alighnment problems. One question though, If this slot(where the washers go in) was used for adjustment, then why is the slot only on the drivers side? mmmm?
action 911:
My last name is Jaynes, thanks.
Bill
more to come....
Bill
more to come....
Herb,
How is your truck running lately? I thought I had seen you post a pretty long list of problems one time. By the way, your washers probably saved me a set of front tires. Thanks.
Silver 2000 Built 5/26/00
#3299 of 4966
Bone Stock
SnugTop Tonneau Cover
#3299 of 4966
Bone Stock
Cabraco, You'll have to ask Ford that question? I don't know????
DOGMAN, I'm back in the swing of things. I now have an 01 motor with the 01 blower and upper manifold. Put the truck on the dyno last weekend and got 370hp/462ft ;-) that was with about 62 miles on the motor!! Can't wait intill she gets loose. I have a Pro-M mass air/Sal's lastest chip. Bassani cat back.
I found out that there is an sensor that has to be move from one side of the manifold to the other on the 01. About 12 to 14 inch wire harness and your done. I feel sorry for the people that had to use the old manifold!! THERE IS SOME HP IN THE 01 MANIFOLD!!! I have to take the truck back to the dealer on Monday to fix the air condition condensor that was dented by the motor change. I also have an exhaust leak on the driver's side exhaust manifold.
HJ
HJ
I just ordered the cam bolts, but I am confused. Do they go in the upper or lower control arms? Thanks, Jeff
2000 White Lightning
PSP & JDM custom chip
JDM 90mm Mass Air
JDM aluminum drive shaft
4.10 gears
et 1/4 mi 13.14 (before JDM parts, after JDM ???)
Retrax tannaux cover
Bedrug
'65 Mustang with 347 stroker
'67 Corvette, ZZ502/502
JDM 90mm Mass Air
4.10 gears
Bedrug
