Help with Autometer boost gauge. I only have 6 lbs. of boost!!!
I installed my gauge pod this afternoon. I noticed that the boost gauge with the engine off shows 1 in. hg. At idle it hold 20 in. hg. Is this right? I hope the gauge is screwed up because I can only get 7 lbs. of boost at WOT! And thats only for a second right before shift change. More like 6 lbs. until right before red line. If the gauge is right no wonder I can't get in the 12's! My in dash gauge shows 10 lbs. Any ideas?
Jerry
Jerry
How did you tap into the boost area? It's possible you have an orifice restriction, or bleed-off, where you T'd off for your new gauge causing the Autometer to read low. And then of course it's possible that the gauge is defective.
If you like I could give you a dozen reasons why you’re not in the 12's, and none of them will be this "low" boost problem your citing.
Anyone else with the Autometer boost gauge reading low boost? I hooked it up with the factory dash gauge so both would work at the same time. Something is wrong. The dash gauge shows 11 lbs. the Autometer shows 6 lbs. And no, I don't have any leaks. I get the same reading on the Autometer with or without the dash gauge hooked up.
Jerry
Jerry Jordan
99.5 Red Hot Bolt
13.303 @ 101.64(stock F1 tires)
PSP filter and chip
chrome SVT wheels
Impulse Lo-Pro bed cover
94 Firehawk #295 black
71 Cutlass conv.
Piper PA28-235
74 Suzuki TS185 (128 original miles)
Jerry
Jerry Jordan
99.5 Red Hot Bolt
PSP filter and chip
chrome SVT wheels
71 Cutlass conv.
Piper PA28-235
The guage may not be properly adjusted from the factory. Does it read exacly "0" when the vehicle is off? If not, read below.
Hint:
Stick your finger in the back of the guage. You'll feel a metal rim. Apply pressure to the rim until the guage reads "0" when the pressure is released.
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, BellTech 3/4 drop, Ford MotorSport Chrome Lightning wheels, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 PT Cruiser - Limited Edition
2001 EB Expedition
Hint:
Rich
2001 EB Expedition
Jerry - your gauges are probably reading correctly - my factory boost shows 10# but my autometer only shows 7# at WOT - I believe the autometer - hoping to get to the 8# rated boost of the supercharger with a filter kit install --
'01L Black
Snuglid & Bedrug
Lotek w/ boost, A/F, H2O
More to come .......
'01L Black
Snuglid & Bedrug
Thanks everyone for your help. Jim44, I hope the filter helps. I have the PSP filter and still only show 7 # on the Autometer. How much boost does Ford claim? I can't remember.
Jerry
Jerry
I have a 2001 and have 9 psi of boost in 2nd/3rd gear. The only mod is a K&N panel filter. This is on an Autometer gauge.
Scott Weatherford
351W 1993 LX 11.9 @ 118MPH (Drag Radials)
Black 2001 Lightning 13.62 @ ??? MPH
WWW.TheVL.COM/VENOM
[This message has been edited by 351stang (edited 04-09-2001).]
Scott Weatherford
WWW.TheVL.COM/VENOM
