HELP!! More Problems.>>
Old Jun 3, 2000 | 08:12 PM
Burninout101's Avatar
Post
2KSVT150GP
Yes it is a SVT dealer but the only requirments to be a SVT dealer are that you have to have 1 million dollars in parts at your dealership, no special mechanic just parts
Old Mar 31, 2001 | 10:58 PM
Silver_2000's Avatar
Question
Justen
Did you ever figure out what the codes were ????
I have same codes
Doug
Old Apr 1, 2001 | 12:51 AM
Post
Doug
shoot me an email
Burninout101@aol.com
Old Apr 1, 2001 | 01:00 AM
clonetek's Avatar
Post
hey now... clue the rest of us in!!!
brooks
Old Apr 1, 2001 | 11:33 AM
Lightfootning's Avatar
Post
Sounds like you have been driving that thing kinda HARD, I wonder if THAT has anything to do with all the problems?.
You should have have taken it back to the dealer for a checkup the first time it would not burn em off ALL the way through 1st and chirp 2nd. I would be upset if I had a 2-3 shift "stubble" also. And the "neddle" half hotter than normal ? Grind "adn" a pop from the tranny ? 15ft burn out and no marks ? And do not forget the "idealing" problem.
Old Apr 1, 2001 | 01:16 PM
Fast Gator's Avatar
Cool
Just curious, you say your truck never had a chip in it, but it use to chrip the tires shifting to second. Every stock computer shuts down 4 cylinders between shifts, or so I thought
Old Apr 1, 2001 | 01:41 PM
Post
Most of my problems were due to BAD gas and a clouged filter. The convertor also was going bad and eventualy went.
Old Apr 1, 2001 | 02:40 PM
SLP 97 CAMARO SS GUY's Avatar
Post
lol, i have had my camaro SS for 3 years, never had one problem with it. ford, quality is job 1!! LIGHTNING IS A BEAUTIFUL TRUCK, BUT ISNT WORTH THE HEADACHES.
[This message has been edited by SLP 97 CAMARO SS GUY (edited 04-01-2001).]
Old Apr 3, 2001 | 12:11 AM
alphadoggy's Avatar
Red face
Coincidence? I don't think so. I thought I would try the odometer diagnosis trick this morning to see if it might give me a clue why my O.D. off light is blinking, before I take it in for service. I got the same damned code, dtc 5284. My oil pressure gauge reads perfectly fine, the pressure is right in the middle, not too low, not too high, so I doubt very much that there is a problem with the oil pressure switch. I wonder if this is some kind of default code on the Lightning? Didn't tell me a damned thing about my tranny, though.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old Apr 3, 2001 | 08:27 PM
ZorPrime's Avatar
Post
please do not feed the troll
1999 Lightning
12.88 @ 104.5
JDM Chip(untested)
PSP Filter Kit
JL RamAir
3.73 Gears
Old Apr 4, 2001 | 12:59 AM
MadMaxSC's Avatar
Red face
shut down to 4 cylinders between shifts?..ROTFLMAO V-8-6-4 was out with the CADDYLACKS...LOL
Old Apr 4, 2001 | 08:12 AM
BlueFlareside's Avatar
Post
alphadoggy,
I had the blinking O/D light on my F-150 XLT and it was a bad selenoid for the 1-2 shift on the trans. A few others have had the same thing. Mine was shifting kind of strange. Is yours shifting any different?
Old Apr 4, 2001 | 08:29 AM
99svtlightning's Avatar
Post
Our oil pressure guage is just a switch, oil pressure or no oil pressure. There is no way to tell how high or low it is.
99 Lightning, Bassani exhaust, JL Ram Air, Superchip(JL Programmed), Level 10 shift kit. 12.8 at 105.3.
Next up: Lower Blower pulley and 90mm MAF.
Old Apr 4, 2001 | 08:37 AM
SVT Bob's Avatar
Cool
Burninout 101, I dont want you angry with me. These trucks are pretty tough.But maybe you have been doing to many burnout,s on the 101. Bob.
Old Apr 4, 2001 | 02:15 PM
alphadoggy's Avatar
Red face
Yeah, Blue, I posted earlier, my 1-2 shift is really screwed up. I thought perhaps it had something to do with my recent install of the shift kit, it almost seemed that it was bumping into the rev limiter, but that doesn't make much sense since the shift kit doesn't alter shift rpm, only pressure, and the chip was not reprogrammed for a different shift point. Your theory about the solenoid makes a lot more sense.
And 99, if the oil pressure gauge is just a switch, what's the point of the needle, all you'd need is a warning light? According to my manual the needle is supposed to fluctuate according to the oil pressure.
And MadMax, laugh all you want, I'm pretty sure Gator is correct, the ecu is programmed to shut down 4 cylinders momentarily during the 1-2 shift so that the wheels won't break loose, which evidently Ford thought would be too disconcerting to us Lightning drivers. The chips correct this, which is why we all get scratch on the 1-2 shift now.
