What kind of FERRARI was this?
Old Mar 31, 2001 | 11:14 PM
Lightningquick's Avatar
Post What kind of FERRARI was this?
Ok,I was at an auto auction last week and saw a dark blue Ferrari there.It was a new one(used though) It was the kind that has the bright red motor in the back and the glass lid covering it.It was very nice looking but wrong color for me.This is the first time I saw car bring over 100k dollars at auction and the buyer even got a standing ovation for buying it.I see 60-70k dollar mercades every day but a ferrari at over 100k .....ouch I am also wondering if any of you guys might know what this car is actually worth or what it cost new.
Old Mar 31, 2001 | 11:26 PM
DoesStrikeTwice's Avatar
Post
The car you describe is the 360 Modena. Sweet ride but I fancy the new 911 Turbo much more and for a tad less.
Old Mar 31, 2001 | 11:32 PM
BlackLight's Avatar
Lightbulb
http://www.ferrari.it/menu/frameeng.html
"Powered by a normally aspirated, 400 hp, 3.6-litre, 40-valve, 8-cylinder engine the 360 Modena..."
To quote Ferris Bueller:
If you have the means, I highly recommend you pick one up...
[This message has been edited by BlackLight (edited 03-31-2001).]
Old Mar 31, 2001 | 11:33 PM
JoeLightning's Avatar
Post
Could it have been a 360 Modena? (all taken from www.die-autobahn.de/f360 )
Here are the specs:
Price..................$152,250 USD
Vehicle Type..................2-passenger, 2-door coupe
Sound System..................Ferrari AM/FM-stereo radio/CD changer, 4 speakers
Major Standard Accessories..................power steering, windows, and locks; A/C; tilting and telescoping steering wheel; rear defroster
Color..................red, yellow, silver, maroon, violet, blue, black
Dimensions & Capacities
Lenth..................4472.2 mm/176.3 in
Width..................1917.7 mm/75.6 in
Height..................1210 mm/47.7 in
Wheelbase..................2595 mm/102.4 in
Front Track..................1666.6 mm/65.7 in
Rear Track..................1613.3 mm/63.6 in
Frontal Area..................2.03 sq m/21.9 sq ft
Ground Clearance..................129.3 mm/5.1 in
Dry Weight..................1292.2 kgs/2843 lbs
Curb Weight..................1392.7 kgs/3064 lbs
Weight Distrubition, f/r..................43/57
Tank Capacitity..................95 lt/25.1 gal
Oil Capacity..................8.9 lt/9.5 qt
Water Capacity..................19.9 lt/21.1 qt
Engine
Engine Type..................dohc V8 in 90°, aluminum block and heads
Bore & Stroke...................85 x 79 mm/3.35 x 3.11 in
Unit Displacement..................448.2 cc/26.8 cu. in
Total Displacement..................3586 cc/219 cu. in
Compression Ratio..................11:1
Horsepower..................395 bhp @ 8500 rpm
Torque..................275 lb-ft @ 4750 rpm
Redline..................8500 rpm
Engine-Control System..................2 Bosch Motronic ME 7.3s with port fuel injection
Valve Gear..................belt-driven double overhead cams, 5 valves per cylinder, hydraulic lifters, variable exhaust valve timing
Emission Controls..................3-way catalytic converter, feedback air-fuel-ratio control
Drivetrain
Transmission..................6-speed manual with automatic shifting and clutch
Final-drive ratio..................4.44:1, electronic limited slip
Gear.......Ratio.........Mph/1000 rpm........Speed in gears
1............3.29...........5.3..............45 mph @ 8500 rpm
2............2.16...........8.0..............68 mph @ 8500 rpm
3............1.61...........10.8.............91 mph @ 8500 rpm
4............1.27...........13.6............116 mph @ 8500 rpm
5............1.03...........16.8............143 mph @ 8500 rpm
6............0.85...........20.4............173 mph @ 8500 rpm
Interior
Front Seat Volume..................1.47 cu. m/52 cu. ft
Luggage Space..................0.23 cu. m/8 cu. ft
Front Seats..................bucket
Seat Adjustments..................fore and aft, seatback angle, lumbar support, upper side bolsters
Restraint Systems..................manual 3-point belts, driver and passenger airbags
Chassis & Body
Layout..................mid engine/rear drive
Body/Frame..................aluminum/extruded aluminum
Front Suspension..................upper & lower A-arms, coil springs, tube shocks, anti-roll bar
Rear Suspension..................upper & lower A-arms, toe links, coil springs, tube shocks, anti-roll bar
Wheels and Tires
Wheel Size f/r..................7.5 x 18 in/10.0 x 18 in
Wheel Type..................cast aluminum
Tires Radial Tubeless..................
Tire Manufacturer..................Goodyear Eagle F1 GS Fiorano
Front Tires..................215/45 ZR 18
Rear Tires..................275/40 ZR 18
Inflation Pressure f/r..................32/29 psi
Brakes
Front..................Brembo 11.8 in
Rear...................Brembo 11.8 in
Power Assist..................vacuum with anti-lock control
Braking from 60 mph..................33.5 m/110 ft
Braking from 80 mph..................57.3 m/188 ft
70-0 mph @ Impending Lockup..................48.4 m/159 ft
Steering
Type..................rack-and-pinion, power-assisted
Turns lock-to-lock..................3.1
Turning circle curb-to-curb..................35.4 ft
Interior Sound Level
Idle..................54 dBA
Full-Throttle Acceleration..................90 dBA
70 mph Cruising..................77 dBA
70 mph Coasting..................76 dBA
Fuel Economy
EPA City Driving..................66.6 kpl/11 mpg
EPA Highway Driving..................96.8 kpl/16 mpg
Acceleration
0-30 mph/48 kph..................1.9 sec
0-40 mph/64 kph..................2.5 sec
0-50 mph/80 kph..................3.6 sec
0-60 mph/96 kph..................4.3 sec
0-70 mph/112 kph..................5.8 sec
0-80 mph/128 kph..................7.1 sec
0-90 mph/144 kph..................8.7 sec
0-100 mph/160 kph..................10.5 sec
0-110 mph/176 kph..................12.4 sec
0-120 mph/192 kph..................15.1 sec
0-130 mph/208 kph..................17.9 sec
0-140 mph/224 kph..................21.9 sec
0-150 mph/240 kph..................27.1 sec
0-160 mph/256 kph..................35.3 sec
Street Start, 5-60 mph/8-96 kph..................5.6 sec
Top-gear acceleration, 30-50 mph/48-80 kph..................7.4 sec
50-70 mph/80-112 kph..................7.4 sec
Standing 1/4 mile..................13.0 sec @ 179 kph/112 mph
Standing 1 kilometer..................22.9 sec
Performance
Top Speed..................302 kph/189 mph
Slalom..................107.8 kph/67.4 mph
Old Mar 31, 2001 | 11:37 PM
FlyingDutchman's Avatar
Smile
Lightningquick,
The only Ferrari with a transparant cover is the F40. The production From 1988 to 1992.
Price more or less $300.000.00
F 40
Engine
Number of cylinders and arrangement
8 in 90° V.
Bore and stroke
82 x 69.5 mm.
Unitary and total capacity
367 / 2,936 cc.
Position
Rear-centre longitudinal.
Cylinder block and head
Light alloy.
Compression ratio
7.8:1.
Max. power output
478 bhp at 7,000 rpm; 163 bhp/litre.
Timing gear
4 valves per cylinder, 2 overhead camshafts.
Fuel feed
2 IHI turbos with heat exchanger, Weber-Marelli electronic injection.
Ignition
Weber-Marelli IAW electronic.
Transmission
Clutch
Dry twin-plate.
Gearbox
5 speeds + reverse.
Differential
ZF self-locking.
Frame
Type and material
Steel tubes, with composite elements.
Front suspension
Independent, transverse quadrilaterals, coil springs, coaxial Koni dampers, transverse anti-roll bars.
Rear suspension
Brakes
Ventilated discs.
Steering
Rack and pinion.
Fuel tank
120 litres.
Cooling system
1 front radiator.
Dimensions
Length, width and max. height
4,430 / 1,980 / 1,130 mm
Wheelbase and front/rear track
2,450 / 1,594 / 1,610 mm.
Tyres
Front 245-40 ZR 17, rear 335-35 ZR 17.
Weight empty
1,100 kg. (2178 Pound)
Performance
Top speed
324 km/h.Top Speed 201 MPH
0-60 3 seconds
FD
Old Mar 31, 2001 | 11:38 PM
Redneck Ferrari's Avatar
Post
Thats a 360 Modena, yours is a
Redneck Ferrari!
Old Apr 1, 2001 | 09:31 AM
Post
The picture clearly shows the same FERRARI.It Is a MODENA.Nice car but i could not and would not spend that much on a car.I would rather buy a 2003 viper/corvette and Lightning for the same and have more fun with those.By the way it was like a 2000 or a 2001 and it was actually shipped from overseas from the looks of the paperwork.And yes,the price seems right concidering this car brought $108k at auction.Imagine that.Here we all bitch about losing 5k on our Lightning when the poor person who bought this just a year ago lost $50k.....OUCH!!
Old Apr 1, 2001 | 07:52 PM
2000Black's Avatar
Post
Car and Driver just happened to review the convertible version in this month's issue. They tested it along side an Aston Martin DB7 Vantage Volante (convertible), and the BMW Z8. They list it as doing the 1/4 mile in 13.2 seconds @ 106 mph. The issue also has a one or two page blurb on the 2001 Lightning. It's a pretty decent read!
2000 Black Lightning
#1326 of 4966
Born on 03/20/2000
PSP Chip
PSP Filter
Best time: 13.248 @ 104.4 mph
[This message has been edited by 2000Black (edited 04-01-2001).]
Old Apr 2, 2001 | 07:40 PM
2nd Bolt's Avatar
Post
WOW!!! $108K That guy is one lucky SOB, The actual price on those is not $158K it is more like $200K and certain options will push it even higher!
Jeff
Old Apr 2, 2001 | 09:26 PM
Post
My veiw on this knowing that it is a DEALER ONLY auction is that the person who bought it did it for one of two reasons.Either he bought it to resell like we all do and if you are gonna spend $108k on one paticular vechicle,You must expect to make a small fortune on it.Also knowing that it came from HERB CHAMBERS dealership which has many many differnt dealerships including a HIGH HIGH line dealership,like Mercades and BMW,It makes me think that this is even a high dollar vechicle for them and wanted to unload it and this car must be very hard to retail.The only other reason i can see how this person bought it is to drive it and have a show piece for a year or so and plans on at least getting his money back by retailing it a year later.These cars im sure lose value very fast with every year like caddilacs and lincons.Either way who ever bought it has DEEEEEP pockets.
Old Apr 3, 2001 | 12:50 AM
Post
This is what that Ferari will get you..................you hope
http://durassic.esmartweb.com/gallery11/2.html
[This message has been edited by Redneck Ferrari (edited 04-03-2001).]
Old Apr 3, 2001 | 08:54 PM
alphadoggy's Avatar
Cool
Here is a pic of my valet washing my Ferrari.
http://www.zing.com/picture/pb3bdef2...6.jpg.orig.jpg
I would say in my dreams, but in my dreams it would be an F50 (if you're gonna dream, you might as well dream big).
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit, TransGo shift kit,
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
http://www.zing.com/album/?id=429389...4647875&idx=15
gmvye@pacbell.net
Old Apr 4, 2001 | 02:18 PM
alphadoggy's Avatar
Talking
btt - I can't let this slide without some kind of response. Marcus?
Old Apr 4, 2001 | 02:35 PM
MRBBQMAN's Avatar
Wink
Who took that pic, Stevie Wonder?? center that thang
Old Apr 4, 2001 | 02:47 PM
Skank Dog's Avatar
Post
MRBBQMAN, LMAO!! I agree!!! I was just about to get "sprung" and alphadoggy cut da *** of her!! WTF!! CENTER THAT THANG ALPHY!!!
