Any ones brakes sqeak around 5000 miles?
Old Mar 28, 2001 | 10:44 PM
Ashenor's Avatar
Post Any ones brakes sqeak around 5000 miles?
Just got my truck out of winter storage and after about 300 miles my brakes are starting to sqeak. Should i already have to replace brake pads at 500 miles?
Old Mar 28, 2001 | 10:57 PM
2000Black's Avatar
Post
Mine squeal and I have over 10,000. This is the second set of pads too.
2000 Black Lightning
#1326 of 4966
Born on 03/20/2000
PSP Chip
PSP Filter
Best time: 13.248 @ 104.4 mph
Old Mar 28, 2001 | 11:04 PM
SLP 97 CAMARO SS GUY's Avatar
Post
a brake squeak does not mean u need new pads. a few months ago, i put all new rotors and pads in my car, front and back, original equipment right from the dealer and they are starting to squeak very slightly already. number 1 complaint with brakes is squeaking. i have people everyday come in and ask to have their car looked at cause the brakes squeak. i take it for a test drive and return to put it up on lift and remove all wheels just to see that the pads are all like new and the rotors are glazed and shiny. when i tell them what they will need to do to get rid of the little squeak and what it will cost, they decide to just live with it. the same way the squeak appeared, it may very well disappear. sometimes it is just brake dust too. hope this helps, Mike
[This message has been edited by SLP 97 CAMARO SS GUY (edited 03-28-2001).]
Old Mar 29, 2001 | 10:33 AM
Ashenor's Avatar
Post
Thanks for the replies. Hope its just a sqeak.
Old Apr 1, 2001 | 09:07 AM
wilywilky's Avatar
Post
Ashenor:
My L acquired the annoying squeal at around 5000 miles. The sound was persistent and at times embarrassing.
To eliminate the noise I tried a technique called "seating the pads". This involves application of the brakes while under power until brake fade begins to occur, then continue driving for a minute to allow the rotors to cool, then repeat sequence two to three times.
It is imperative that this trick is done on a stretch of road or highway where you will not have to stop for lights, traffic, etc. after you have heated up the rotors, or warping of the rotors may occur.
I have almost 23k miles on my L (and the original pads), and have not had the squeal since seating the pads.
Wilk
'97 F-150 4x4 Super Cab; XLT 139" Wheelbase Flairside; Silver Frost Clearcoat; 4.6L. (Romeo); 4-spd Automatic Transmission; Preferred Equipment Package 507A; 3.55 Limited Slip Axle; Electronic Shift 4x4; California Emissions; Sliding Rear Window; Trailer Towing Package; Off-Road Package; 6-Way Power Driver's Seat; Remote Keyless Entry/Anti Theft; 6-Disc CD Changer; Ford Bedliner; Ford Running Boards; Ford 600 Plus Vehicle Security System; Ford Nose Mask; Roll n Lock Tonneau Cover; Ford PremiumCare Extended Service Plan (5 year/100,000 miles).
2000 SVT F-150 LIGHTNING XLT; 120" Wheelbase; Flareside; 5.4L EFI SOHC V8 SC Engine; 4-SPD Automatic; Silver Clearcoat Metallic; SVT Online Store Lightning Front End Mask; Roll n Lock Tonneau Cover.
Old Apr 1, 2001 | 09:33 AM
95rcobra's Avatar
Post
WilyWilky, I have the brake squeal too and want to ask you when you seat the pads are you driving a highway speed of 55 or can you do it at 30 or 35. does it really matter how fast you are going. thanks for the tip and info. 95rcobra.
Old Apr 1, 2001 | 09:26 PM
wilywilky's Avatar
Post
95cobra:
The speed at which you seat the pads is immaterial. You'll have to keep the power on to overcome the braking forces. Brake fade will occur sooner at higher speeds, of course, but we're talking seconds here.
Wilk
