pulled the intercooler to clean it and theres some anti freeze?!
Old Dec 11, 2007 | 09:56 AM
lurker's Avatar
Originally Posted by trucknut1378
lurker it wont let me pm you and i cant send you emails. could you try emailing or PMing me.
Looks like you need to edit your profile options to allow private messaging?
Old Dec 11, 2007 | 12:52 PM
trucknut1378's Avatar
went to my user cp but didnt see an option for it. but i got your email and have replied
Old Dec 11, 2007 | 03:22 PM
thepawn's Avatar
You can also run it dry in the mean time, just pull the intercooler pump fuse so you don't burn it out.
I ran my dry for a few months waiting for the replacement...you'll lose HP due to the higher intake temps, but you'll be okay.
--Dan
Old Dec 11, 2007 | 05:51 PM
so far i only have one option for a new one. and that would be lurker. is there an aftermarket one that is better? if so any websites? would it be better to run it dry than to keep fluid in it and just keep filling up the resivor? if its better to run it dry where could i find the fuse for the ic pump?
Old Dec 13, 2007 | 02:27 AM
thepawn's Avatar
if you keep putting fluid in it, you'll keep blasting it through your engine.
Dry just means higher intake temps and less efficiency = less hp.
It's actually a relay...do a quick search, there's a post I made asking about where it was and someone put up a diagram.
Old Jan 3, 2008 | 09:03 PM
1999lightning's Avatar
Hey mike i have a 99 lightning would a intercooler from a 2001- 2004 fit my L
Old Jan 4, 2008 | 05:57 PM
i think i can answer this one....no it will not fit UNLESS you have the adaptor plate that will allow it to fit...OR you find a lower and upper intake from the 01-04 and install it. from ford the cheapest i could get them to go down was 1015..shipped. i just had to prepay. i think that the first question i've been able to answer since i joined i know i'm still a noob. but im learning. this place is a plethera <sp? of knowledge you guys are awsome
