OBD2 data recording cheep
I just installed an OBD program from www.obd-2.com This thing works great. It will continuiously record 30 or so data streams for later playback. rpm/temp/air temp/rpm/O2 mixture.... The data cable is around $150 the software is free for download. Way Cool
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
[This message has been edited by awhittle (edited 03-31-2001).]
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
I was told that the L has a knock sensor but Ford disconected it. The tires were sending a sound thru the chassis that was being heard by the sensor as knock. The other thing that appears to be missing is manifold pressure. Does anyone know if there is a MAP sensor on an L to read boost? It does read the MAP on my GM van.
Andy
Andy
which o2 reading.. i saw a couple on his screen.
i have spots for 8 guages tho..
brooks
*edit* i just looked at the odb webpage.. his module wont work on my ford.. crap.
[This message has been edited by clonetek (edited 04-01-2001).]
brooks
Does anyone know what is a good full power reading for voltage on the o2 sensors? It jumps all over at cruse but runs around .9V on the power. Is that about normal?
Check out http://www.gadgetseller.com/gauges/
see FAQ and AF gauges 101
Andy
[This message has been edited by awhittle (edited 04-01-2001).]
Andy
