First oil change .........
Old Mar 22, 2001 | 01:18 PM
FRITZ's Avatar
Exclamation
Come on guy's,need some help here.What are you 01 oweners going to use. I have 950mi on
my L,want to change oil at 1000mi (This weekend).
FRITZ,Silver 2001 "L"
Old Mar 22, 2001 | 01:34 PM
MID_12s's Avatar
Post
I am going to use 5-30 mobil 1 for my first change. I do not think that ford changed anything on the 2001 engine's oil system, or bearing clearance, so I am sticking to 5-30.
Old Mar 22, 2001 | 01:38 PM
'01ArrestMeRed's Avatar
Smile
I have not picked up my new truck as of yet. When it's time to change the oil in it, I'm sticking with the 5W/20 oil. That's what SVT recommended. I heard that some NAPA stores carry 5W/20 Valvoline. Ford also has the 5W/20 oil. NEO also makes a synthetic 5W/20. Mobil makes the 5W/20 also.
http://dallnd6.dal.mobil.com/GIS/MobilPDS.nsf/26b7 c4b33367a4a086256665004e4266/666d4fcfd829f702852569300044420c?OpenDocument
The 5W/20 oil helped to reduce friction and also helped Ford to attain LEV (low emission vehicle) status.
I hopes this helps you. I don't want to get into a warranty pissing match about wrong weight oil should a warranty issue ever arise.
Rick
'01 Red Lightning Ordered 11/30/00
Build week of 2/19/01
Built On 2/20/01
Shipped Via Rail 2/27/01
ETA Of 3/12/01
Mods :
G-Tech Pro
Bel Radar/Laser Detector
[This message has been edited by '01ArrestMeRed (edited 03-22-2001).]
Old Mar 22, 2001 | 01:42 PM
smcconaghie's Avatar
Post
Wal-Mart also carries the Motorcraft 5w-20 oil at about $15/case.
Stick with the recommended oil weight.
'99 Ford F-150 Lariat Supercab 4x4 ORP
5.4L Triton V-8
Deep Wedgewood Blue
MODS TO COME:
K&N FIPK
Gibson Dual Sport Truck Exhaust
A.R.E. LSII Hard Tonneau Cover
Old Mar 22, 2001 | 02:01 PM
BLackBoLT99's Avatar
Suspended For Rules Violations
Post
When I had my firt oil change, I was told by the head tech (who had HIS Gen 1 Lightning there that same day {runs mid 12's on street tires}) that the 5w-20 was put in there to keep the emissions low, i.e. we have those "ultra low emissions" . He said by my next oil change, he'd put in Mobile 1 synthetic in it. Or some sort of Synthetic. By the way, for my firt oil change, I stuck with the 5w-20, by the next one, I'm switching it.
-Marcus M.
Email-SnakEyez60@aol.com
Black 2001 recieved 2/10/01. Pictures coming soon.
Moderator:BLackBoLT01 www.svtperformance.com
Old Mar 22, 2001 | 02:09 PM
clonetek's Avatar
Post
same here marcus...
i put regular oil in it for the first oil change, then switched to mobil synthetic for the second oil change..
tell them to leave the plug out for a while when you get your oil changed to synthetic.. try to let as much regular oil drip out. thats what i did.. it couldnt hurt.
brooks
[This message has been edited by clonetek (edited 03-22-2001).]
Old Mar 22, 2001 | 05:52 PM
SVT Bob's Avatar
Post
Be careful, if you put the wrong weight oil in,and that motor goes sour.You could have a battle on your hands with Ford.
Old Mar 22, 2001 | 07:47 PM
01Black-SVT's Avatar
Post
I use 5w-20 and always will, if thats what ford wants me to put in my lightning then I will
01,Black,Lightning
K@N air filter
Super flip Chip
Old Mar 22, 2001 | 07:51 PM
SVT_01_Sparky's Avatar
Post
Hey FRITZ,
My service manager told me to use 5w-30 until 3000 miles, then would be best time to change to Mobil 1, again 5w-30. Will also change oil at 1000 mile mark.
Good Luck
Bill
2001 Black Lightning
Born 01/09/01
Brought home 02/08/01
A.R.E. LS II W/wing
Bedrug
More to come
spark-doctor@mediaone.net
[This message has been edited by SVT_01_Sparky (edited 03-22-2001).]
Old Mar 22, 2001 | 08:59 PM
Undy's Avatar
Post
I called SVT today on the 5w 30w Mobil one issue for the 01. He said there was no warrantee issue at all with the change. He, in fact, thought it was a good idea. He recommended doing the first change on the 01 at about 1200 miles with the standard 5w 20w and then convert to the mobil at about 5000 miles. He said that would give the engine plenty of time to break in.
2001L, red, born 2/6 and arrived 2/28!!!
Let the mods begin....
1969 Vette coupe, 496ci stroker big block, aluminum heads, 4340 crank & H-beam rods, JE 10.8 pistons, roller everything, McLeod dual disk clutch w/ aluminum flywheel, Richmond 6 spd, 3" dual exhaust, 300hp nitrous fogger, no strip time...
1985 FoToLet, work truck, 85 Toyota 4x4 (started as), Reading bed, ladder racks, 8" lift, 33 x 12.5's, Vette 350 4 bolt motor, Hooker Super Comp headers, Ford 9" rear, Toyota front diff, turbo 350 coupled to a Toyota transfer case, 410 gears, a/c & power steering. f-a-a-s-t A/C & heat calls..... my specialty.
web page: http://personal.picusnet.com/undy
Old Mar 23, 2001 | 12:07 AM
FRITZ's Avatar
Exclamation First oil change .........
I went to the local Ford dealer (where i got my L)to pick up some of the new oil 5w-20w,
and filter.The service manger was standing near by and pulled me aside.He told me if it was his L he would put 5w-30w in it.So what do i put in it? 5w-20 or 5w-30w ???
Old Mar 23, 2001 | 09:33 AM
FRITZ's Avatar
Talking
I'm going with the 5w-20w,that warranty stuff
got me thinking.If you change your own oil like i do, and anything happends to the engine,you would have to show the receipt.The receipt would show the oil weight.
