OEM Lightning Differential ???
What is the standard differential in the L? Is it the 9.75 with LS like in the regular F150's?
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Optima Red Top Battery
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Performance Accesories Lift Lips by Mountain Enterprises
Superlift 3" lift blocks
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
McGard Premium Wheel Locks
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
I don't believe it is the same as a regular F150 pickup, but it is a 9.75" rear end. Then again I guess I have never paid attention to the rear end of a normal truck.
Brian
99 red lightning, bassani complete system #1610 of 4000
2000 Lightning, PSP filter/chip, svo throttle body, Bassani, 4.10's
2000 super duty v10
Arctic cat 400 4x4
Cobra "R" #131 of 300
Moderator
www.svtperformance.com
My vehicles http://www.zing.com/album/?id=4293160925
Brian
2000 super duty v10
Arctic cat 400 4x4
Moderator
From what I've read, it comes right off the shelf from the Expeditions. Could be wrong though..
Black '00
#1,757 built 3/30/00
Clear corners
JDM street program
JDM 2# blower pulley (ordered)
J.L. Stage II ram-air
FRPP Oval throttle body (ordered)
90mm MAF
MagnaFlow Exhaust
Black '00
Clear corners
JDM street program
90mm MAF
MagnaFlow Exhaust
Thanks for the replies. Lets see what other board members have to say. I am very curious about that. I will try to go to the dealer to check the labels of one of the L's or maybe ask them directly, but in reality sometimes I don't trust them too much.
Modifications:
K&N FIPK
Modifications:
K&N FIPK
The standard f150 has an 8.8" ring gear with 31 spline axles, the Lightning has the 9.75" ring gear with 34 spline axles, the same as the f250 light duty and the expedition, the f250 and f350 super duty, single rear wheel uses a 10.5" ring gear and 35 spline axles, for comparison sake the chevy 1500 uses 8.4" woosy gears
[This message has been edited by MID_12s (edited 03-21-2001).]
One of my concerns here are basically, what is the difference (besides the limited slip that I don't have) between my 9.75 Sterling and the L's 9.75 Sterling?
Modifications:
K&N FIPK
Modifications:
K&N FIPK
the f-150's have 9.75" in them???, I have 3 and none of them have 9.75's???
ohhhh, but the 5.4 f-150's do have 9.75"s, my bad
HI!... JMTRUCK : The sterling 9.75 in the LIGHTNING and the STERLING 9.75 in the 5.4 equipped regular F-150's are exactly the same. From the SVT engineers and other people that I have talked to about the strength of the 9.75 rearend all say the same thing. It is just as strong as the old FORD 9 inch and can easily handle 500H.P and 500FT/LBS of torque. Some LIGHTNING guys are run slicks and going low 12's with this rearend with no problems yet. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
