Drive shaft bolts?
Old Mar 20, 2001 | 08:05 AM
John893's Avatar
Post Drive shaft bolts?
I am trying to remove my drive shaft and can't get the bolts to move. What is the best way to get the bolts off? I know I need a 12 mm 12 point wrench or socket.
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Mar 20, 2001 | 08:51 AM
sixpipes's Avatar
Cool
Leverage. I had the rear wheels off the groung when I removed mine. I put the transmission in neutral and rotated the rear wheels until the bolts were in the best position, put the transmission back in park and then used a cheater bar to break them loose. I had to repeat the process a couple of times. I know it's a lot of hassle, but I still have all the skin on my knuckles.
Old Mar 20, 2001 | 09:01 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Post
either a 3/8" torque wrench or put on some gloves, get underneath the yoke and benchpress the driver's side lose then pull the passenger side lose.
Old Mar 20, 2001 | 09:33 AM
Spiro99SVT's Avatar
Post
I simply used a box wrench for the bolts, but also used an additional open-end wrench interlocked together for furhter leverage. Came off quite easy to be honest Hope this helps
Spiro-
12.373 @ 110.15
Best 60' 1.76
@ 4700 without the Go-Go juice
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Old Mar 20, 2001 | 02:43 PM
curmudgen's Avatar
Question
These bolts torque at what? 45lbs?
Red 99
Old Mar 20, 2001 | 02:46 PM
Spiro99SVT's Avatar
Post
torqued?? yup...goodentight
Old Mar 20, 2001 | 02:50 PM
John893's Avatar
Post
I just bought a 12 point 1/2 drive 12mm socket. I think it will work better then the little wrench I was using last night. My torque wrench will have to be my arm. When I arm can't turn the bolt any more then the bolt is tight!
Old Mar 20, 2001 | 05:41 PM
Bolt's Avatar
Post
I don't think you can get a 1/2" drive socket in there. 3/8" with a breaker will fit as well as a box. I also used Loctite on the bolts.
[This message has been edited by Bolt (edited 03-20-2001).]
Old Mar 20, 2001 | 06:22 PM
bggroth's Avatar
Post
I agree with Bolt, can't get a 1/2" ratchet in there.
Old Mar 20, 2001 | 11:38 PM
John893's Avatar
Post
I just finihed up the install of the drive shaft. I was able to get the 1/2 drive on the bolt using a 2-3 inch extention. I did not have to move the truck at all. I was able to get at all 4 bolts from one position. The hardest part was getting the old drive shaft to budge once the bolts were out. I had a little trouble getting the bolts back in and tight with 1/2 drive because of the huge drive shaft.
93 Teal Cobra #4656
Old Mar 21, 2001 | 01:31 AM
Jay Lincoln's Avatar
Post
I did the same as JOHN893. I bought a 12mm 12pt., 1/2 drive socket. When I reinstalled the bolts, I used blue loctite and torqued them to 83 ft lbs. This is what the Ford service manual recommends.
Red 00"
Pro-M mass air
Swanson Chip
*******'s bed cover
