Think we might have a problem
Old Nov 3, 2007 | 08:21 PM
RidiculousRed's Avatar
Well I have noticed that when I pull the truck into the garage after my drive home from work (which is all highway at about 80 for 15miles) the smell of somthing burnning under the hood. I have checked for leaks and nothing. Smells like oil today after getting to work I smelt it go and on the drive to work I got on it but opened the hood and it was smoking around the oil seperater area. I dont have one but in that location. If anyone has any info thanks for the help.
Old Nov 3, 2007 | 08:46 PM
lightninquick's Avatar
maybe the pcv needs attention
Old Nov 3, 2007 | 09:42 PM
can you explain about the pvc?
Old Nov 3, 2007 | 09:43 PM
can you explain about the pcv? my bad on the mis spel
Old Nov 4, 2007 | 01:31 PM
STRYKS2X's Avatar
mine does it too. you need an oil separator since our PCV system tends to pull oil vapors into the intake system.
Old Nov 4, 2007 | 06:20 PM
Ricki F-150's Avatar
Maybe you have a small oil seepage from the valve cover gasket at the rear.
Old Nov 10, 2007 | 08:02 AM
Ok so after having 24hr duty and reading almost everything about oil separator and breathers I still do not know which I should do, but I know something needs to be done because the oil burning smell is getting worse. So last min input woul dbe great thanks.
