Octane Boosters?
Old Mar 18, 2001 | 07:15 PM
Toadster's Avatar
Question Octane Boosters?
I just installed a Superchip in the Bolt(WOW!!). However position 1 is Pump Premium which is 93 here(Shell or Amoco). Position 2 is Racing gas 98 octane. The question I have for everyone is about octane in a can. DO THEY WORK and if so which one is the best. The truck will not be driven every day so the price is not a problem, and as far as getting racing gas I have not seen any in the area in a long timeso buying it is not really an option.
So thanks for any and all opinions.
2001 RED Adopted 2/10/2001 at 11:00am
Bed Rug
Retrax cover (sweet unit)
(Waiting on chip availability)
V 1
Old Mar 18, 2001 | 07:34 PM
Spiro99SVT's Avatar
Post
Since AUGUST 99, I have always recommend the the NITROUS OXIDE OCTANE BOOSTER in the black box. Its the race version with Nitro Methane. Pep-Boys has them for around 11 bucks a bottle, and it's safe for the cats.
Spiro-
12.373 @ 110.15
Best 60' 1.76
@ 4700 without the Go-Go juice
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
-Stock Torque Convertor
Empty Pockets Racing DE-NJ
Old Mar 18, 2001 | 09:43 PM
Mondo1's Avatar
Post
I've used the outlaw booster on my Gen 1 and it worked fine.A little more than most but less than the NOS. I've heard that it works for most detonating problems.I also heard that the NOS always works.I would have gone to the NOS next if the outlaw brand failed,but it didn't.I think I paid 5 or 6 dollars.Also sold at Pep Boys and K-mart, yes I said K-Mart.
Old Mar 18, 2001 | 09:49 PM
fordtec2001's Avatar
Post
Unburned hydrocarbons coat the platinum/palladium covered honeycomb inside the catalytic converter and prevent their reaction with oxygen. This not only renders the converter useless, from an emissions standpoint, but it increases fuel consumption and eventually causes the vehicle to stall due to backpressure on the exhaust system.
Old Mar 18, 2001 | 09:59 PM
Mondo1's Avatar
Post
I thought hydrocarbons were a afterproduct of burned fuels.How can they be unburned if they the end result of the burnt air/fuel gasses?
Old Mar 18, 2001 | 10:03 PM
Twinturbo Ranger's Avatar
Thumbs up
Back when I had troubles and had to use octane booster the only one that worked was the NOS offroad version,but I never tried the race version. The regular street version did not work,but all thats fixed now. Just my experience. Thanks Mike
00 White Lightning
JL (2)Superchip
JL Air Filter
JL Driveshaft Loop
JDM Lower Blower Pulley
2001 90 mm Mass Air
2" Lowering Shackles
Custom built and designed single 3.5 exhaust with Flowmaster Race Muffler
93 Ford Ranger
FI 302 with 185 AFR heads
GT-40 intake w/ported lower
65 mm TB
66 lb injectors controlled by Western Motorsports SDS fuel injection
TDC Stage 2 twin turbos
AOD trans w/Lentch strip valvebody
10 inch convertor and single input shaft
8.8 rearend w/mosier 31 spline axles and 3.08 gears
Chassis Tech Ladder bar suspension
and plenty more !!
Old Mar 18, 2001 | 10:47 PM
noelvm's Avatar
Post
Most of these additives are snake oil. Find a dealer who sells Sunoco 104 GT PLUS UNLEADED RACING GASOLINE. Not only will it run great but you will never have to worry about clogged or dirty injectors! At the strip I run a mixture of at least 60%-80% 104 to 93.
noelvm
"ANYTHING OTHER THAN 1ST, SUCKS" (D.Earnhardt)
99.5 Red Ligntning, Mobil 1, PRO-M 80 MM MAF/filter, Custom Superchip, Eldebrock 5512 muffler, CAL TRACS, MT ET Streets, best time (1/8) 8.19, Bugflector II, G&H Lens covers head & fog, 200 WT Pioneer 4 CH AMP, BOSE 301 SERIES IV SPEAKERS (IN BACK)LONESTAR RACEWAY 2000 ROOKIE OF THE YEAR (AT 56)
70 Vette LS-6 454 (gathering dust in the garage)
Old Mar 18, 2001 | 11:32 PM
Spiro99SVT's Avatar
Post
Here in DE I am fortunate enough to have Sunoco GT 100 octane available at a local Royal Farms mini-mart for only 2.99 gl
Follow this link www.racegas.com and click on GT 100 locations to see if theres a pump near you
SUNOCO GTTM UNLEADED
For classics, street rods, muscle cars, motorcycles, exotics, and showroom stock racing. Sunoco GTTM Unleaded is a pacesetter. It has a comprehensive additive package for greater engine protection and cleanliness. And it’s unsurpassed for racing cars that require unleaded gasoline, and those with knock sensors, computers, or turbo-charged engines. GTTM Unleaded is formulated to meet OPRG standards for reformulated gasolines within all 50 states.
Fuel Property Typical Specifications
Specific Gravity 0.760
Pump Octane (R+M)/2 100
Reid Vapor Pressure 8
Distillation,°F
Initial Boiling Pt. 90
10% Evap. 150
50% Evap. 210
90% Evap. 230
Final Boiling Pt. 260
Color Clear
SUNOCO GT PLUSTM UNLEADED
Sunoco’s newest high performance unleaded racing fuel. Created for race cars, bikes, and boats with compression ratios up to 14:1, GT PlusTM is designed with the professional racer in mind, and should not be used on the street.
Specific Gravity 0.735
Pump Octane (R+M)/2 104
Reid Vapor Pressure 9
Distillation,°F
Initial Boiling Pt. 100
10% Evap. 135
50% Evap. 200
90% Evap. 230
Final Boiling Pt. 255
Color Lt. Blue
Spiro-
12.373 @ 110.15
Best 60' 1.76
-Stock Meter
-Stock TB
-Stock Heads
-Stock motor
Old Mar 18, 2001 | 11:43 PM
whitestx's Avatar
Post
Also, try one of the small general aviation airports in your area. They have 100 (blue) or 110 (green) low lead, so no cats!! Most will sell to you if you tell them it's going to the track or if you put it in a can. I've seen it happen both here in CA and in MD.
