Oil Pressure Switch?
Old Mar 18, 2001 | 10:27 PM
1RedDevil's Avatar
Question Oil Pressure Switch?
Can anyone tell me where the factory oil pressure switch is located? Want to install mechanical guage.
Already tried a search but found nothing.
Thanks,
Dan
PSP TOTALLY MODIFIED
Best ET 12.57
Best MPH 107.89
Best 60 ft 1.72
So-Far!!
Man, I LOVE These PSP PRODUCTS!!!
(Thanks Sal!!!!)
Old Mar 18, 2001 | 10:33 PM
fordtec2001's Avatar
Post
need more info what year and engine size ect u know whats the 411 dude ?
Old Mar 18, 2001 | 10:58 PM
Neal's Avatar
Cool
HI!... 1RedDEVIL : It's located where the oil filter screws on to the aluminum adapter connecting the filter to the engine block. It's underneeth the oil filter adapter and the sender aims towards the rear of the truck. If you get under your truck and look right behind the oil filter you will see a wire harness going to a electrical sender with 1/4 NPT thread. What ever you do, make sure you install the factory sender back with a "T" fitting so you can run both senders. If you don't your engine light will come on. Hope this helps you out.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
[This message has been edited by Neal (edited 03-18-2001).]
