engine fogging
Old Oct 22, 2007 | 08:50 PM
lightning25's Avatar
engine fogging
folks,
it's about time to put our babies away for the winter, and i want to know about engine fogging oils.
Last year i did not use a fogging oil, but my truck was stored away in a sealed metal storage facility and the truck was in a carbag (car jacket) with 5lbs of dessicant to absorb the moisture.
The question is; how can one use fogging oil on our truck with the Pain in the a$$ task of removing the spark plugs and trying to get the oil into the engine?
Could the fogging oil be sprayed into the intake??
Or would i just not waste the hassle as i have a drying agent under the truck that will evapourate all moisture in the storage area the truck is in??
Thanks,
Sean
Old Oct 24, 2007 | 01:38 PM
TrackBeast's Avatar
Its not worth the hassle other than on small engines.
I add Lucas fuel treatment which contains oil to lube the entire fuel system and put fresh oil in the crank.
You can get Lucas at Crappy Tire.
Old Oct 24, 2007 | 02:01 PM
pitstain's Avatar
I have always used Marvel Mystery Oil when storing any motor or fuel for long periods.
