engine stumble.
Old Oct 20, 2007 | 10:27 PM
00 white lightn's Avatar
engine stumble.
i found when the egr is unplugged it goes away, has a low rpm misfire, well i replaced the egr valve, dpfe sensor. and egr vacume solenoid. same problem. also a full tune up was done, fuel filter, plugs, coil packs everything. same problem. well i am reading 1.6 inch of vacume on the egr at idle which is normal. but i noticed with the egr plugged up and working my timing at idle is 16 or so and cruising its like 40-45 degrees of timing. it seems high, when i unplug the egr my timing drops to 30 or so and it runs fine. well i back probed the egr solenoid according to my troubleshooting steps and it say if you ground the egr solenoid and you get more than 4 in of vacume when you do this (at the egr) then you have a bad pcm, but the truck runs good with the egr unhooked, and i can communicate fine with everything. on a side note. the battery did go dead recently and i replaced it. could this be a computer relearn, or is this a bad pcm?
Old Nov 4, 2007 | 02:17 PM
y2klightning's Avatar
hmm... subscribing....
