Will 00 Airraid fit 01 L ?
Old Mar 12, 2001 | 02:59 PM
Daves00L's Avatar
Question Will 00 Airraid fit 01 L ?
will the Airraid off my 00 L fit my 01 L ?
thanks
dave o
Old Mar 12, 2001 | 06:03 PM
JagcLightning's Avatar
Post
Sorta!?! The hole in the airraid that connects the MAF to the filter is only 80mm, so you have to enlarge it with a file if you want it to meet the 90mm opening. I had JDM do it for me when I purchased their 90mm Mass Air. They had a little handheld griding machine so it was no problem opening it up. You could still connect the new 90mm Mass Air to the 80mm opening but that would restrict airflow and defeat the purpose of having a 90mm Mass Air.
2000 White Lightning
JDM custom chip
JDM 90mm Mass Air
JDM lower pulley
JDM aluminum drive shaft
4.10 gears
et 1/4 mi 13.14 (before JDM parts, after JDM ???)
Retrax tannaux cover
Bedrug
'65 Mustang with 347 stroker
'67 Corvette, ZZ502/502
