Pulley Install
Old Mar 3, 2001 | 02:36 PM
Silver-Bolt's Avatar
Post Pulley Install
Installed the PSP lower pulley. Smokin! Incredible throttle response. Do it soon. Also discover that the factory pulley adapter was loose. Upon removal of the factory pulley the adapter that bolts to the balancer was only finger tight. There are 3 bolts that hold the adapter on and I removed the with my fingers. Glad I found it. Could have been ugly. Bad part is there is noway to check without removing the pulley.
2000 Silver Lightning 13.82 (stock)
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
Snug-Lid
In the works:
Level 10 converter
4-Link
Old Mar 3, 2001 | 02:42 PM
Bolt's Avatar
Unhappy
We are all waiting to experience the Smokin! Incredible throttle response.
Old Mar 3, 2001 | 03:35 PM
wrightlightning's Avatar
Post
Silver-Bolt, what pulley did you install (2 lb, 3 lb)?
Black '00
#2216
Old Mar 3, 2001 | 09:27 PM
Post
I installed the PSP lower. Between 2-3lbs. Probably closer to 3 if you run and open filter or ram-air. It makes a difference for sure. Much more responsive. Now I just need the single blade TB.
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
Snug-Lid
In the works:
Level 10 converter
4-Link
Old Mar 10, 2001 | 01:05 AM
Red-lightning's Avatar
Post
jUST STARTING WITH MY MODS WHAT DOES THE PULLEY COST AND WHERE IS A GOOD PLACE TO PURCHASE IT.
Old Mar 11, 2001 | 08:45 PM
Post
http://www.powersurgeperformance.net
Sal will take care of all your Go-Fast needs.
PSP 4-way
PSP Filter Kit
PSP Lower Pulley
Level 10 Shift kit
Snug-Lid
In the works:
Level 10 converter
4-Link
