Anyone ever measure the ohms across tran temp sensor?
Originally Posted by Tim Skelton
Are you talking about factory or aftermarket?
And again, how are you measuring it?
There is a ToT (Transmission Oil Temperature) sensor in the solenoid, it sends signal to the PCM and in certain Super Duty models there is a dash Trans Temp guage. For aftermarket guages, you can remove the pipe plug in the test pressure port and plug in the sensor there.
