buddy needs help
Old Sep 30, 2007 | 12:02 PM
04LIGHTING's Avatar
Question buddy needs help
one of my buddies i s having problems with his 02 lightning. Not sure if its a dirty maf or what.
the truck idles fine and revs fine once is in neutral but when you put it in drive the engine starts vibrating and it kinnda hessitates when you get on the gas. any ideas and it is not throwing any codes.
Old Sep 30, 2007 | 12:56 PM
Certified Drunk's Avatar
When was the fuel filter changed?
Old Sep 30, 2007 | 03:36 PM
04LIGHTING's Avatar
last time it went on the dyno, about 3 months ago
Old Sep 30, 2007 | 04:12 PM
F151's Avatar
Sounds like fuel delivery....... pressure check at the rails??
Old Sep 30, 2007 | 05:22 PM
04LIGHTING's Avatar
thanks guys, ill let him know when i roll by his house. we really cant figure this out. hes gonna bring it to the local ford performance tuning shop tuesday morning.
Old Sep 30, 2007 | 07:23 PM
promodlightning's Avatar
Check your plugs.
Old Oct 1, 2007 | 06:31 PM
MotoXracing22's Avatar
Originally Posted by promodlightning
Check your plugs.
x2. This made a world of difference on the old truck but it was at 105,000 miles.
Old Oct 1, 2007 | 07:12 PM
todd abbott's Avatar
I agree with the above, start with plugs and a fuel filter then post the results and we'll move on.
Old Oct 2, 2007 | 01:06 PM
04LIGHTING's Avatar
we just brought the truck in and the mech told us is either the plugs or the coilpacks. he's looking at it as we speak. is it common for the coilpacks to go bad?
Old Oct 2, 2007 | 03:45 PM
Houndog's Avatar
CP's will thro a code and tell you which one is bad, Had CP's go bad but never a plug...
Old Oct 2, 2007 | 07:25 PM
04LIGHTING's Avatar
turned out the vibration was coming from the torque converter. it is just about shot.which one do you all recommend? the cops and the plugs are good.
Old Oct 2, 2007 | 07:26 PM
04LIGHTING's Avatar
i read somewhere that some diesel trucks also have the same tranny. will that fit on the lightning trans?
Old Oct 7, 2007 | 02:31 PM
04LIGHTING's Avatar
we brought the truck to the shop where the they found out that the tranny fluid was darker than usual for the miles on ther truck. The trans was flushed, everything was checked and double checked and now it runs smooth as silk, so he saved 1000's in repairs.
