11s Lightnings step in and help
Old Oct 7, 2007 | 08:29 PM
chief40al's Avatar
Hi Guys
I heard my name.
Been there and done that
Old Oct 8, 2007 | 03:22 PM
04LIGHTING's Avatar
my current mods are in my sig. what else would i need to get in the 11's besides some slicks. thanks in advance
Old Oct 8, 2007 | 03:23 PM
04LIGHTING's Avatar
here they go
Old Oct 9, 2007 | 11:43 AM
SILVERLIGHTNING's Avatar
Originally Posted by Rob_00Lightning
And your right there are many in NJ that have done it including Vinnie, Gator, Al, Fast Freddy, and and and ....
Freddy still does it every time out with the Mag now (believe me it's pretty much the same as an Eaton).
Hey Joe! Long time, no see.
For what it's worth, I ran a 12.03 with a two pound lower, stock upper, stock eaton, all blower. Here's an old Sig Photo:
Joe,
All you need is an old copy of MMFF. That will make 'em a believer.
Fred
Old Oct 13, 2007 | 09:43 AM
RED 92's Avatar
Originally Posted by TriPodRacing
I don't post here much, but I need some help from all of you.
I have a bunch of none believers.
I have few people saying it is not possible to run 11s with Stock Block/heads/cams and eaton. No spray either.
Its possible, I think I could do it with a few more bucks...
Im at 12.2 at 112 with a 4lb tune and ported eaton. The biggest E.T. drop came from 45lb 16" fronts and 44lb M&H drag radials or my 43lb Hoosiers run the same with either....I ran 12.20 with no spare or hitch and with the passenger seat and with the tailgate on. I have the battery over the right rear tire and I add solid chunks of ice to my IC reservoir (frozen bottled water), cut the plastic and drop them in before the run. I pulled the passenger seat and ran 12.26 the same night so I might have run better if I made the first run of the night without the seat.
I would think to run 11's with your criteria I would need hi-flow cats, 6lb new tune....and or a stall and a perfect launch and conditions..? ...otherwise I think 40-50HP from heads and cams would do it for me with the 4lb.
