Possible electrical problem...HELP
One month after I bought my L I changed the headlights and the fog lights to Hyperwhite bulbs. I rarely used the fog lamps.
About one month ago I started using the fog lamps every day (just because it looks cool).
After about two weeks the fog lamp on the passenger side went out. So I bought new bulbs. And here it is 2 weeks later and the fog light on the passenger side went out. That’s two times, same side, and about the same time span.
Any thoughts? After reading the horror stories about Ford’s service departments I am afraid to take it in for fear they will "F" up the entire electrical system.
k
2000 Silver Lightning
#2372 of 4966
SnugLid
BedRug
dual Ravin Z-33 Exhaust
Valentine 1
Hyper Bright Headlamps and Foglamps
Mobil 1 Tri Synthetic and Mobil1 Filter
Mobil1 FactoryFill Plaque in Engine Bay
Matter/Antimatter Exchange Unit
Thinking about those Nitto Tires
http://www.zing.com/album/?id=4293534625
Try putting the factory bulbs back in and see if they work better. Maybee it is the hyperwhite bulbs that are causing the problems.
SILVER 2001 LIGHTNING
Built 02/14/01
Picked up 03/03/01
Sportmasters tonneau
Bedrug
http://members.tripod.com/donf150/Welcome/id7.html
Built 02/14/01
Picked up 03/03/01
Bedrug
I put the superwhite bulbs in my truck and one of my fog lights blew out i replaced the bulb and has been working fine now one of my mechanic friends said to make sure not to touch the bulb with your fingers because the oil from your skin if it gets on the bulb can cause it to blow so next tiem i made sure i didnt touch the bulb and has been working fine to and i to use my fog lights all the time hope that it helps
