fuel alternatives?
Old Sep 24, 2007 | 09:58 AM
jeffy's Avatar
fuel alternatives?
Hey guys! New poster here. I was wondering if you could buy regular 87 gas and put in a bottle of 104 octane booster? Premium is so expensive!
Old Sep 24, 2007 | 12:21 PM
LTNDave's Avatar
Keep in mind that 1 Octane number is 10 octane points... so a booster that claims that it will boost it 8 points will only raise 87 octane gas to 87.8 NOT 95 octane.
They only way I can see to make 87 usable is to mix 104 unleaded race gas with it and a 5.00 a gallon (in my area) its not feaseable.
Just buy the 93 and be done with it or 91 if its all you have in your area.
Old Sep 24, 2007 | 01:55 PM
SILVER2000SVT's Avatar
I disagree, Premium has never been cheaper, comparitively speaking.
When regular 87 was $1.00, premium was $0.20 more at $1.20. Now with regular 87 at $2.60 premium is still only $0.20 more. By the time you spent $5 on a octane booster you would have spent the same amount on money (assuming 25gal) if you would have just filled up with premium. There are only a couple of octane boosters out there that will raise your fuel the 60 octane points to be the equivalent of running premium and I'm not sure if you can get any of them for under $5?
Old Sep 25, 2007 | 10:16 AM
SWThomas's Avatar
You would actually spend more by filling up with 87 octane and using a bottle of octane booster. Think about it.... premium is what, $0.20 more than regular per gallon. That's about $5 more per fill-up give or take. I know a bottle of 104 Octane Booster costs more than $5. Just run the premium fuel.
Old Sep 25, 2007 | 12:48 PM
Allcarfan's Avatar
premium is actually $.28-$.34 more than regular around here.
Old Sep 25, 2007 | 02:20 PM
SWThomas's Avatar
Well, that sucks.
Old Sep 25, 2007 | 02:35 PM
01TruBluGT's Avatar
To the OP, any particular reason you would want to run higher octane fuel?
Old Sep 25, 2007 | 03:54 PM
pitstain's Avatar
Please tell me you don't own a Lightning......and if you do, then you should have considered gas prices before buying a hot rod....
Old Sep 25, 2007 | 05:04 PM
SWThomas's Avatar
Because Lightnings require premium fuel at a minimum.
