suspension question
Paul:
The BellTech 3/4 kit comes with new/smaller bumpstops. Kit includes hangers, shackles and front springs.
Nice quality kit.
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, BellTech 3/4 drop, Ford MotorSport Chrome Lightning wheels, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 PT Cruiser - Limited Edition
2001 EB Expedition
Nice quality kit.
Rich
2001 EB Expedition
The other issue that I have yet to see addressed is the angle of the shocks compared to the direction that the axle is traveling. Look at the stock rear shocks on an L. One goes forward and at an angle of about 45 deg. The other goes to the rear at about that same angle. This is done to hide/cover up a problem with the torque of the rear axle trying to turn the springs into an S shape when you jump on the gas. The two different directions that the shocks go is to keep the shocks from causing a similar S bend in the springs when you hit a vertical bump. The real problem when you lower the truck even farther is that these shocks goto an even shallower angle and do even less in bump. (Wheel travel)*(cos angle)=(shock travel) To make things even worse, You run out of vertical travel due to the bumpstops. Stock the L rear suspension has only about 4 inches of suspension travel B4 you start to hit the stops. If you lower the truck..All of these things get worse. The solution to this whole mess is to build a real independent rear suspension starting with a dif out of a SVT Mustang R or an old Jag that has as I remember a 9" Ford Rear but the street rodders have grabed most of them. The Vet rear would most likely be strong enough. Bottom line, Lowering an L has some baggage that goes along with it.
Hope this helps
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
[This message has been edited by awhittle (edited 03-06-2001).]
Hope this helps
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
Rich,
I am not using one kit I am doing a custom set up. I need these sold sepertly. Thanks for the help.
Awhittle,
Do you think that rouch thought of this problem when they came up with there suspension package?
Awhittle,
How about adding 2 more shocks at the rear, so that each wheel will have 2 shocks, one pointing forward and 1 rear. This way you will have double the cosine of the force in the shock, holding/stabilising the axle.
BlackLight
Interesting Idea but what you would need to do is mount two new shocks vertical to control bump and let the two stock ones control wheel hop. The new shocks would need to be real short or you could cut holes into the bed and mount them to the roll cage. Cool...we can now justify the new cage. Wile we are at it we can mount the 5 point harness to it.
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
Andy Whittle
White 2000
#2482 of 4966
Built 4/27/00
My Autocross car
Sounds like something out of a Mustang with their quad shock system. If you go with a IRS, use the one from the T-Bird. It was designed for a heavier vehicle than the Cobra one, and might last for 2 launches.
