Rear-End #'s ???
Old Aug 22, 2007 | 04:01 PM
naha08's Avatar
Rear-End #'s ???
So i checked out my rear-end and the tag on it says. L 73 975 1C13
If I am correct the 73 =3.73 gears
-the 975= the 9.75 rear-end
and what ever the hell the rest means.
Anybody who as any knowledge, input would be great.. THX
Quick low-down. Busted the axle on the truck. Go a new one installed and the truck does not run the same. Truck use to to accel like a bastard and chip second. Now it does not.
What should I do?
Old Aug 22, 2007 | 04:37 PM
Norm's Avatar
L = limited slip
I believe the 1C13 is a date code.
Old Aug 22, 2007 | 06:07 PM
Neal's Avatar
Cool
HI!... You have a STERLING 9.75 rearend with LIMITED SLIP and 3.73 gear ratio.
Old Aug 22, 2007 | 06:36 PM
tlfwatch's Avatar
Question This Could Be Bad
What should I do?
THE differential you speak of could be a 355 you had installed or the differential has not been adjusted to specks i believe should be between 9000 and 13000th i am sure you had your tolorence checked before you installed it. if you did not this is important that you do
