Metco Trac-Link Belltech Kit
Old Aug 17, 2007 | 12:03 AM
Ford Rulez All's Avatar
Is anyone running the Metco trac-link kit that is made for trucks with belltech lowering kits? I just got them today and I have no idea how the front bracket mounts to the truck. Does anyone have pics of these installed on their trucks? I also hope I have all the parts because it doesn't look like the other pics I see of them on the net but that could be because they are the belltch version.
Old Aug 17, 2007 | 05:50 PM
I was under the truck today tryin to figure out how these things mount in the front and I took some pics. I think i see how it goes but my only problem is that the brackets have 2 holes for screws and there is only one hole in the frame. I am not sure if this is the way its supposed to be so the brackets work on either side or if my truck just doesnt have the holes.
Old Aug 18, 2007 | 07:30 AM
QKSILVR's Avatar
The wide flat part bolts to the bottom of the frame. Hence the large oval hole for the rivet in the frame. Take out the spring bolt and attach the Metco piece on the outside of the belltech hanger and put the bolt back in. Then you can drill your other hole. Looks like your going to hack off that piece you have attached to your hanger for your exhaust though.
