I think torque converter is staying locked up HELP!!!!!!
about once every 3 days my L will go dead when i come to a stop the trans pulls the motor down until it goes dead . A trans man told me that either the lock up solenoid was bad or the chip was the problem I have JL's new program and was wanting to know if anyone else is having this problem
99 lightning pulley, Downs filter, superchip 12.93 104 new baby
69 camaro 7.90@180 10.5w 3200 lbs. 89 turbo T/A 11.41 121 mph(SOLD)
I have the new JL program and everything is fine. I also vote for the solenoid. Strip the mods and take it to the dealer. ;-)
99 Lightning, Bassani exhaust, JL Ram Air, Superchip(JL Programmed), Level 10 shift kit. No ET yet.
Sold- 98 Cobra. FM 2 Chamber, K&N, Steeda Triax, 4.10's, MAC offroad H. Best Cobra 1/4mile 13.8.
Sold- 96 Z28 ATI Procharged 13.5.
Trackboy : did you try it without the chip? most likely its not the chip. however if you want send it back and i'll re-burn it.i havn't had ANY complaints about the converter staying locked up.let me know how you make out...JL
93 cobra 10.90@127.00
99 lightning (black)
e.t. 12.41 @ 110.8
best mph 110.8
60 ft. 1.79
JL superchip
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
SuperChip Dist.!
(Man i love this truck!)
_ _ _ _ _ _____ _ _ _ _ _
JohnnyLightning Performance
E-mail: jlightningracing@cs.com
WEB:JohnnylightningPerf.com
svtperformance.com
e.t. 12.41 @ 110.8
best mph 110.8
60 ft. 1.79
JL superchip
JL ram air
JL Powercooler
2# pulley
Level 10 shift kit
SuperChip Dist.!
svtperformance.com
If the chip caused the solonoid to fail, it may have written a code to the PCM, and your warranty is toast if it did. Signals sent to the PCM that are out of the factory specs can be recorded when a failure occurs, I don't know if they can source the signal, but if they know you had a chip, bet that the dealer will thry to blame the modification for the failure. Sorry to be the bringer of bad news, hope it works out.
G
G
you boys need to get your L worked on at my dealership mods seem to be no ptoblem. The problem is they send all the tranny work to a local shop and of course they say it is the chip
