AeroForce Scan Gauge
Old Aug 2, 2007 | 08:55 PM
Screwed2002's Avatar
I looked on the website, and it seems that they only have this available for 00-04 gen 2 lightnings. My question is, if I am doing an L swap to an 02 Screw, and keeping the same ECM (updating with a tune) will I be able to use this gauge, or is there something else I would need to interface with my ECM?
Old Aug 2, 2007 | 10:10 PM
Mastertvtech's Avatar
The gauge will work either way. It could be coded as a L and if you were missing any parameters it could be reflashed with the generic code which works on all Fords 96-present. It will read everything one way or another.
Lew
Old Aug 2, 2007 | 10:20 PM
Nice!!!
Old Aug 2, 2007 | 10:22 PM
So Lew, do you have any indea what paramaters are read by the ECM on the 02 model Screws?
Old Aug 3, 2007 | 07:49 PM
Just like all of the Fords you will see at least the following: (typical Fords see between 18 and 23 available parameters)
MPH
RPM
MPG
o2 voltages B1 and B2
fuel trim B1 and B2 (probably)
trans temp
batt voltage
fuel %
coolant temp
maf (probably)
throttle volts
trans torque
engine duty
fuel duty (probably)
barometer
All of the subfunctions will work:
1/4, 1/8, 0-60 and et's
record 2 sets of parameters
shift lights
MPG calculation
The L and Cobra are coded differently. They get IAT 1 and 2 but lose fuel duty, along with a few other tweaks.
Lew
