RTKILLA Stereo question????
Old Feb 6, 2001 | 06:54 PM
John893's Avatar
Post RTKILLA Stereo question????
Hey I asked you about running a power wire the other day and you said to run it behind the black trim against the firewall, and then push it though the firewall right below the steering column. I can't find the hole you are talking about. Do I have to make the hole? Or should there be one there already? My lightning is a 2000.
Thanks for the help
John
93 Teal Cobra #4656
2000 Silver Lightning #4524
Old Feb 6, 2001 | 07:33 PM
BulldogSVT's Avatar
Banned
Post
its there already...rubber grommet
Old Feb 6, 2001 | 07:59 PM
John893's Avatar
Post
I can't seam to find it!!!!!!!!!!!!!!!!
Well I will go back out and look again in a few minutes.
93 Teal Cobra #4656
Old Feb 7, 2001 | 04:14 AM
clonetek's Avatar
Post
maybe its not there on the "00?
rt & bulldog have "99's i believe..
duck? you there?
Old Feb 7, 2001 | 02:59 PM
RTKILLA's Avatar
Post
Or razor burn, if none of those are their, she's to young. ???wait what are we talking about again????
Grass on the field, play ball!!!!!!!
Old enough to eat turkey. old enough to get stuffed. That ones sick, but I had to say it.
She has allot of toys on her.
MY BABIES STAT'S
Built 5/4/99
# 917 of 4000
2001 ET: 12.???, we'll find out soon.
When the green light drops, the bullsh*t stops.
Old Feb 7, 2001 | 04:50 PM
John893's Avatar
Post
Does anyone with a 2000 have a good suggestion for where to run the power wire through the firewall? What would be the issues with cutting a small hole in the rubber piece that the steering rack goes though?
John
93 Teal Cobra #4656
Old Feb 7, 2001 | 04:57 PM
RTKILLA's Avatar
Post
NONE.
Cut it, there's nothing wrong with doing that. there no other way.
Old Feb 8, 2001 | 12:09 AM
RTKILLA's Avatar
Post
Sorry It took me so long to reply, I was having my wisdom teeth pulled out. Anyway, There was a hole there when I looked, It was big enough to fit the 4 gauge wire no problem, Maybe like clonetek said, there is no hole on the 2000. I don't see why, but its always a possibility. If there is no hole then just drill one and put a grommet in.
MY BABIES STAT'S
Built 5/4/99
# 917 of 4000
Old Feb 8, 2001 | 12:18 AM
clonetek's Avatar
Post
hey man.. look for the hair. LOL
had to say it.
John893 said:
<font face="Verdana, Arial" size="2">I can't seam to find it!!!!!!!!!!!!!!!!</font>
Old Feb 9, 2001 | 12:18 AM
eddie silver lightning's Avatar
Post
There is a rubber gromet hole next to the brake booster on the driver side i have two amp power wires run through it.I ran the wire under the drivers side step panel, back to my amps.email me if you have any q,s
supercharger pulley,373gears,blinker mirrors,seanhyland chip,massair,silverRhinoliner,cervini hood
Old Feb 9, 2001 | 10:23 AM
Speedracer29's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by John893:
John
</font>
This would be a good place to put it. If you will take the drivers seat out and run the wire under the carpet you don't have to use as much wire, and you will not have to worry about seeing the wire. That is if that is easy to do in the L. I did it in my mustang, and jeep, and it worked fine. Just my thoughts.
Jason Hogan #29
www.JasonHogan.com
-2001 Silver L (orderd)
-1997 Roush Mustang- too many mods to list
-1998 Jeep Grand Cherokee with 5.9 liter 360 motor
-1999 Chevy Extreme
-2000 Ford F350 Dualy
