torque specs--intercooler bolts
Old Jul 20, 2007 | 08:56 AM
halflife's Avatar
what are the correct torque specs for the rear intercooler bolts? I did a search and saw 53 ft lbs but in the shop manuel http://www.lightningrodder.com/forum...read.php?t=225
it looks like it is supposed to be torqued the same and in sequence with the supercharger bolts at 18 ft/lbs then 33 ft/lbs?
thanks
Old Jul 20, 2007 | 11:44 PM
kromdom's Avatar
looks like you found the correct info (page 8): http://www.svtperformance.com/Howto/...er_removal.pdf
Old Jul 22, 2007 | 11:19 AM
Dbl G's Avatar
8lb.'s I/Cooler to Mid Plate
33lb.'s S/C to Mid/Manifold
Old Jul 22, 2007 | 04:17 PM
SVT_KY's Avatar
thanks
53 INCH POUNDS !!! And new bolts all the way around
Then 18 and 33 on the S/C
Charge Air Cooler R and R
