Crack! I Found Crack!
Old Jul 15, 2007 | 01:13 AM
Klitch's Avatar
ok guys, i have a slight dillemer on my hands. i have a turkeypot intake manifold here you guys are pretty familiar with. i was cleaning up my intake manifold getting ready for whenever i get my motor dyno'd and i noticed a very fine crack that almost penetrates from the inside out, in the driver side rear corner up high. it goes through the gasket surface most of the way out, and down about half an inch...
what do i do besides cry?
Old Jul 15, 2007 | 03:43 PM
Dbl G's Avatar
Contact this guy..
http://myworld.ebay.com/ebaymotors/monkeybiscut/
http://cgi.ebay.com/ebaymotors/2002-...QQcmdZViewItem
Old Jul 15, 2007 | 05:36 PM
Klitch's Avatar
hmph, yer just sayin my manifolds a paper weight now?
Old Jul 15, 2007 | 06:03 PM
Dbl G's Avatar
You could pull it and get it welded...
Old Jul 15, 2007 | 06:16 PM
Klitch's Avatar
my buddy's been to school and he's afraid the weld will either crack out at the end of the welds, or may crack out in the middle of the weld. does this sound right? i have the ability to easily get it to someone to be fix'd right now since its sitting on my bench collecting dust.
Old Jul 15, 2007 | 08:05 PM
Dbl G's Avatar
I'm afraid by the time you get it Magnafluxed and welded you will spend more then $150 this charges..And no if welded properly it will not , a weld is stronger (If done properly) then the surrounding areas..
Old Jul 15, 2007 | 08:11 PM
SWThomas's Avatar
Dang, when I read the title of the thread I thought you'd found some drugs hidden in you L somewhere...
Old Jul 16, 2007 | 07:36 AM
Incogneto's Avatar
Turkeypot? JB Weld.
Old Jul 16, 2007 | 02:52 PM
Klitch's Avatar
i appreciate the concern of cost, but i sure hope my best bud can help me with his welding skills after all the cars ive helped him salvage my concern still lies with has it been done sucessfully before? also, are you leading into the surrounding areas may crack?
if i did, i wouldnt post it here and i wouldnt be worried bout fixin a part lol.
Originally Posted by Incogneto
Turkeypot? JB Weld.
im concerned about JB weld patching over the hole, but flaking off later on?
also, what about brazing to fill the crack? i know they use brazing filler and a tig on body panels and small holes in restorations.
