Ok ... I Need Help !!!
Old Jul 11, 2007 | 02:09 PM
SVT_KY's Avatar
Question Ok ... I Need Help !!!
The rebuild is moving along and I need some
advice. The rebuild in gonna be right around 10 grand ...
I want to use upgraded parts where possible.
Anyone able to tell me if this item works well on the 5.4 Liter Fords?
Canton 16-780 Oil Pan.
Thanks for y'alls cherished opinions ... (I mean that !)
The rest of the list ...
BLOCK WORK:
Manley PISTONS
Manley RODS or EAGLE w/ ARP 2000 ROD BOLTS
HEAD WORK (PORT)
MANLEY NEXTEK VALVE SPRINGS
MANLEY TITANIUM RETAINERS
FERRA VALVES
COMP CAMS
CLEVITE BEARINGS
FRONT ENGINE COVER
ARP HEAD STUDS
OIL PUMP
OIL PAN
OIL PICK UP TUBE
DIP STICK TUBE
DIP STICK
ROCKERS
LIFTERS
Cliff
TIMING KIT
OIL PAN BOLTS
OIL PAN GASKET SET
PICK UP TUBE BOLTS
REAR MAIN SEAL
PICK UP TUBE SPACER
Old Jul 11, 2007 | 02:41 PM
Tim Skelton's Avatar
Since you road race, why not use the 15-780 (OEM on 2000 Cobra R) or 15-784? You have to use a remote filter, but I would do that anyway.
Old Jul 11, 2007 | 03:31 PM
Incogneto's Avatar
Ford racing also has the higher capacity truck pan which looks to be the same as the Canton truck specific pan. Melling also now makes a high volume oil pump that will use the stock sized pickup which will come with the Canton pan/windage tray kit.
Old Jul 12, 2007 | 08:14 AM
svtsilverback's Avatar
glad to see the rebuild is coming along cliff. just need to add a twin screw to the list of parts.
Old Jul 12, 2007 | 10:18 AM
LightningTuner's Avatar
I'd use CP pistons instead of the Manleys. For the oil pump, I'd use the Ford Racing pump (basically a stock 4V pump). You'll have to cut the shield off the pickup tube as it doesn't clear in the 5.4. If you want the BEST modular oil pump, get one of the MMR modifed 4V pumps (cryo gears, o-ring seal).
On the pan, the only thing I can tell you is don't use the Moroso one.
Old Jul 13, 2007 | 12:25 PM
White01's Avatar
Cliff, Seen your truck at Modular Depot. Is Ken and boys taking care of you. I got my built motor from them in 04. Good luck with your build.
Rich
Old Jul 14, 2007 | 05:19 PM
Bad as L's Avatar
Yep....there's no more fun to be had than setting your brand new bullet down in the hole only to find out the corners of the oil pan wont let it clear that last couple of inches....good times
Old Jul 15, 2007 | 07:27 AM
retics4me's Avatar
here you go Cliff
http://www.fordracingparts.com/parts...tKeyField=8776
Old Jul 17, 2007 | 05:38 PM
SVT_KY's Avatar
Originally Posted by retics4me
That looks very nice.
Sal, why not the Manley Pistons to go with the rods?
At this late date I might not be able to change but I
would appreciate your wisdom.
Old Jul 17, 2007 | 07:27 PM
TrackBeast's Avatar
Who makes that pan? Is it being sold under another name?
Is it designed for drag or road racing? Capacity?
Not allot of info. on that site.
TB
