launching on street tires
i have a 99 lightning. What is the best way to launch with it? should i put sandbags in the rear? should i launch in 1st or drive? any help would be appreciated, thanks
Preston
99 Black Lightning
Preston
99 Black Lightning
Keep it in drive. You should hold one foot on the brake and use the other on the gas to rev it to ~1000rpm, then let off the brake and slowly ease into it.
Check this out and let us know if you can go: https://www.f150online.com/f150board...ML/008766.html
Jeff
93 Mustang GT: 11.40 @ 124.5 (old combo)
00 Lightning: 13.32 @ 103.5 (JDM chip)
www.unlimited-racing.com
Jeff
Yes, I have 3 sandbags in the rear at all times. Last time I didn't I came acorss an 00 camaro SS, and lost. Since I put them back in, it can go either way, but he usually is pulling away right around 70.
Also, if the track is very sticky, you can leave at up to 1200 rpm, side step the brake & slam the throttle wide open. Works well most of the time for me. 1.90-1.91 60' consistently. Stock weight, but no spare. Lloyd
2000 Black L #2189. Airaid & Superchip R9. Drag Results: Best ET: 13.07 Best MPH 103.09 Best R/T .501 (twice) Best 60' 1.631 on F1's 1973 Cutlass Supreme 455/450HP 4 speed. Too many Mods to list! 95 Olds Aurora 91 S10 305TPI/700r4 project 2000 freightliner FL60 Rollback tow truck My garage overuneth
