Question about removing the fuel evap solenoid
I'm looking for a good place to mount my nitrous kit solenoids on the firewall and I like the spot where the fuel evap solenoid thingy is. My question is... If I remove it and cap off the lines, would it be necessary to have my tune adjusted? I know I might get a CEL, but will it cause any performance problems?
could try this location as well.....
Fuel solenoid mounted using a bolt used to hold down the fuel rail...
Nitrous and Purge Solenoids, mounted using the existing holes on the firewall wire cover.
I was told by JJ not to mount the solenoids to anything on the engine. He said I don't want the solenoids subjected to the vibrations the engine give off. I like where you have the nitrous and purge solenoids mounted but I already have my Aeromotive fuel pressure regulator there.
