Just installed the S/B throttle body...
Old Jan 23, 2001 | 12:10 AM
wrightlightning's Avatar
Question Just installed the S/B throttle body...
and now there is a "whistling" sound at part throttle. Sounds like a possible vacuum leak. Anyone else have this same issue? I can not find any hoses unplugged, and I tightened the tb and clamp very well. Is it possible for the tb to be leaking somehow? I can not hear it unless I am in the cab. Kinda irritating. It may just be more air sucking through the filter easier...?
Throttle response is 100% better, BTW!
Black '00, #2216, Pro-M, Swanson Flip Chip, AIM 2" drop kit, JL Ram Air, S/B TB, 2# pulley on the way!
Old Jan 23, 2001 | 02:33 AM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Post
I had this problem, and so did a few others. Like everyone else, the noise went away after a couple of weeks. Never did find out what that noise was. I could only hear it at atop lights, and not from the outside of the truck. When I shuut the engine off, it seems as though somehthing was slowing down to a halt.
Well, the noise went away.
Old Jan 23, 2001 | 07:12 AM
Spiro99SVT's Avatar
Post
I was surprised myself to hear that, I love the sound of that extra air rushing into the motor
Spiro-
Old Jan 23, 2001 | 10:33 AM
White2000SVT's Avatar
Red face
On my 1987 GT that I used to have, I had installed a 75mm throttle body on it and from the very start I had a slight whistle and it really annoyed me. I ended up taking it off and really inspected it closely. I finally figured out that the problem was a poorly constructed throttle blade. The blade was not even close to fitting properly. I guess that it was not sealing and that seemed to cause the whistle.
That would make sense why Tundra's stopped after a while. The carbon build up and sealed itself.
Just my .02
Spencer
White 2000 L
#2250
Mods:
PSP filter
F-1 AAD Hood
Clear Corners
Coming soon:
Mpulse Lo-pro Tonneau
Chrome SVT rims
Old Jan 23, 2001 | 11:04 AM
PFA's Avatar
PFA
Post
I would agree that you want a good fitting blade but, you don't want it to seal. The only time it is sealed is when it is off. No air will get thru for your engine to breath.
Old Jan 23, 2001 | 01:37 PM
Post
PFA
Before this gets out of hand, just let me say that in no way was I questioning what you said in your post. In fact, like I said, I was actually questioning what I had said. The reason that I knew that it was a poorly constructed throttle plate was that I took the original Ford throttle body and looked at the clearences on it compared to the larger one that I purchased and the larger one had very sloppy gaps around the perimeter of it. I was only posting my thoughts of what the problem might be with wrightlightnings's throttle body.
For all I know it could be something totally different, and not have a thing to do with the throttle blade.
White 2000 L
#2250
Mods:
PSP filter
F-1 AAD Hood
Clear Corners
Coming soon:
Chrome SVT rims
Old Jan 23, 2001 | 02:02 PM
PFA's Avatar
PFA
Red face
Hey,
I'm not trying to start a war here. I was just stating some of the things that I know of and what makes sense to me. If I am wrong, please tell me and how. I am interested just as much as the next about the stuff for our L and what we have purchased and can further modify if needed. Please don't take it the wrong way!
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, LoJack, Valentine 1, Mobil 1
Old Jan 23, 2001 | 02:05 PM
Wink
PFA
It's all good....I feel the same way!!
Can't get mad at a fellow WHITE Lightning owner!!
Spencer
White 2000 L
#2250
Mods:
PSP filter
F-1 AAD Hood
Clear Corners
Coming soon:
Chrome SVT rims
[This message has been edited by White2000SVT (edited 01-23-2001).]
Old Jan 23, 2001 | 02:08 PM
BABolt's Avatar
Talking
Just a little added information. That is not a sloppy gap. The perimeter clearance around the throttle blade was designed that way. If you study the other Ford throttle bodies you will see a "P" hole in the blade(s). No the sound is not a vacuum leak or anything like that. This is a very thin wall casting and from a NVH stand point it would never be tolerated by a customer in production. Unless of course you purchased a Cobra R. In that case your throttle blade was stamped Cobra R.
Old Jan 23, 2001 | 06:02 PM
Post
BABolt....
Not sure if you were aware, but the sloppy gap that I was refering to was on a throttle body that I had on a Mustang. The reason that it was sloppy was that I later found that the throttle body that I bought was actually someone elses product that someone bored out and then tried to fab up a throttle blade for it. The gap around the inside was not even uniform. When you held it up to the light you could really see the poor quality of the throttle blade. Unfortunate for me......
Spencer
White 2000 L
#2250
Mods:
PSP filter
F-1 AAD Hood
Clear Corners
Coming soon:
Chrome SVT rims
Old Jan 23, 2001 | 07:38 PM
Wink
Thanks everyone for all of the posts. I am not unhappy with the throttle body at all. The throttle response is terrific. Just curious why it only "whistles" at slight to part throttle? I guess when I go full throttle I wouldn't be able to hear it anyway with that blower whine!!! :-)
Grady
Old Jan 24, 2001 | 12:29 AM
Mark_2kL's Avatar
Post
There is an idle air solenoid controlled by the computer that lets varying amounts of air in when the throttle blade is(are) completely closed.
Mark
'00 Lightning
'79+ Corvette
Old Jan 24, 2001 | 12:36 AM
Post
Thanks Mark_2kL
I was pretty sure that it was supposed to make a good seal. Had me re-thinking my comment for a minute there.
Old Jan 24, 2001 | 12:52 AM
PFA's Avatar
PFA
Post
OK
I agree with you there. But, what I would like to point out also is that there are those little holes in the orig. TB plates. Can you explain the sealing effect to me of those? I don't believe there should be a totoal seal there.
Old Jan 24, 2001 | 03:10 PM
Red Racer's Avatar
Talking
Have you ever seen how a whistle is made?
The same thing that makes a whistle whistle is what makes your SB throttle body whistle at part throttle. It's more pronounced than the smaller dual bores because of it's size.
My 2 cents.....
Dave
dgoetsch@socal.rr.com
2000 Red SVT Lightning
Superchip R9
JL 12" Powerstack Air Filter
Magnaflow Muffler #12568
Stull Billet Grilles
Line-X Spray-in Bedliner
Snugtop Snuglid
Tinted Side Windows
Lightning Hitch Cover
Many more to come.......
