Bottom radiator hose is leaking
Old Jun 21, 2007 | 08:52 PM
SWThomas's Avatar
Unhappy Bottom radiator hose is leaking
When I was doing the trans lines today I notice my bottom radiator hose has a slight leak where it meets the radiator. It must have just started because I'm under my truck a lot and haven't ever noticed it and I never leave any puddles when I park it. I thought that maybe the clamp wasn't positioned right, but that didn't fix it. Then I moved the clamp back a little and added a worm-gear clamp along with it and that helped a little, but it's still leaking. I'm not sure if the hose is leaking or if there's a crack in the radiator itself. I'm going to get to the bottom of it soon. I was just wondering, if I have to replace the hose, how much do they run and where would be the best place to get it? It looks like it would be pretty expensive since it has all the other hoses branched off of it.
Also, I just flushed the radiator a few days ago and can't help but think that maybe has something to do with it leaking. I don't know how, but it didn't leak before I flushed it.
Old Jun 22, 2007 | 05:27 AM
SVTLIGHTING's Avatar
Had a leak in the same spot. Replaced the hose an fixed problem. They tend to crack when you mess with that clamp to much. It digs into the line and splits it open.
Old Jun 22, 2007 | 05:30 AM
SWThomas's Avatar
I hope that's all it is and it's not a cracked radiator. Either way I'm going to inspect it today.
Old Jun 22, 2007 | 11:04 AM
JeffsLightning's Avatar
Looks like that lower hose is 35 bucks from Ford with the discount and 70 regularly...
Old Jun 22, 2007 | 10:04 PM
SWThomas's Avatar
With what discount?
Old Jun 22, 2007 | 10:15 PM
Originally Posted by SWThomas
With what discount?
Actually it's less than 35.. send me an e-mail.. jchudd@comcast.net
Description Qty MSRP Price Your Price Core Price Total Cost
OEM Catalog
HOSE and CLAMP ASY RAD $66.56 $32.95 $0.00 $32.95
Old Jun 22, 2007 | 10:19 PM
SWThomas's Avatar
OEM Catalog
That seems kind of cheap considering how detailed the hose is. I'm sending you an email now...
Old Jun 22, 2007 | 10:21 PM
I told them what I needed and that was the deal they gave me for a lower radiator hose for a Gen 2 Lightning...
Back at you on the e-mail...enjoy..
Old Jun 22, 2007 | 10:29 PM
SWThomas's Avatar
Okay. Thanks. I didn't knwo you had called them.
Old Jun 24, 2007 | 08:13 PM
SWThomas's Avatar
Well, I inspected it today and it's not the lower radiator hose that's leaking. It's the lower trans line fitting that's directly above it. I don't know why it just started leaking, but I can't help but think that maybe it has something to do with the line upgrade I just did. Maybe I tweaked it a little when I was messing with the lines... How would I go about fixing this? I checked and it's as tight as I can get it. The only thing I can figure is that maybe the o-ring inside is bad. Any ideas???
Old Jun 26, 2007 | 11:25 AM
brain bypass's Avatar
probably a bad o-ring. i replaced mine last night on the upper one, we'll see if the leak stops, looks like it has.
Old Jun 26, 2007 | 01:22 PM
SWThomas's Avatar
Where'd you get the o-ring?
Old Jun 27, 2007 | 12:23 PM
this is pretty shade tree, but i had a bunch of o-rings for garden hoses, and it happened to be the right size. i just needed to stop the leak, and it has been working so far.
if it leaks again, i may try to find the right kind. when i got it apart, my girlfriend wasn't home, and my mustang is down for an engine swap, so i had to see if i have anything laying around that would work.
Old Jun 27, 2007 | 12:40 PM
SWThomas's Avatar
Did you remove the line before you unscrewed the fitting or did you take it all off together?
Old Jun 27, 2007 | 01:38 PM
just took off the the whole thing on the top, slid the ring over the threads, then screwed it back on.
