Alcohol Water Mix in Intercooler?
Hey all, was wondering the probability of running said mixture in the intercooler for dramatically reduced temps. Also wondering about what it might do to the pump,hoses,ect?? What do you guys/gals think??
I thought that someone more knowledgeable than me would have replied by now, but since they didn't, here's my $0.02. Since my intercooler began leaking last November, upon the advice of someone else on this board I have added nothing to the reservoir but distilled water and, occasionally, a pint of alcohol. In my climate I'm not sure that the alcohol is even necessary. So far I have noticed no adverse effects, and the truck still runs fine. However, here is the caveat. The pump requires lubricant, and plain water will not do the job, so occasionally I add a bottle of CarQuest radiator anti-rust and water pump lubricant, $1.19 at my local auto parts store. I am thinking of continuing to do this even after my i/c is replaced; what do you gear heads think?
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, built 2/9/00, #133 of 4966, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
13.39 @ 102.5
gmvye@pacbell.net
the alcohol is used for the cooling effect (same as you feel on your skin), when the mixture is atomized by a hp spray pump system and enters the blower airstream. it won't do much good in a sealed system, or in a drip,drip,drip situation. unless you are using it for antifreeze. it would be better for your engine if it is drinking it, than antifreeze. from the pics we have seen of damaged intercoolers, i can't see where a rust inhibitor/lube would hurt anything on a sealed system. i'd check to see if it might do any xtra damage to the engine, than plain antifreeze would with a leak
God just what I need, A drunk truck. I'm bad enough.
I swear Officer its not me, its the truck, she's drunk.
She has allot of toys on her.
MAY BABIES STAT'S
Built 5/4/99
# 917 of 4000
Best ET. 13.42 at 100.98
best stock 13.96 at ?
2001 ET: 12.???
When the green light drops, the bullsh*t stops.
MAY BABIES STAT'S
Built 5/4/99
# 917 of 4000
2001 ET: 12.???
Of all the suitable/affordable liquids available, pure water is:
1) the cheapest
2) the highest heat capacity.
Diluting it with anything will decrease your intercooler/heat exchanger performance.
1) the cheapest
The antifreeze also inhibits corrosion and increases the boiling point. The tradeoff is a lower heat capacity compared to pure water.
Anything that decreases the surface tension (to get better contact with the metal) also decreases the boiling point, heat capacity and will probably promote foaming...
Suppose I wanted to fill the i/c system with ice water at the strip? How would I go about draining the coolant that is in there? And, I know its gotta be in the manual, but do you know off hand what the capacity of the i/c system is?
