Fuel Pressure less than 19 PSI
Old Jun 15, 2007 | 03:12 PM
GetStruck's Avatar
Fixed. The Y fitting on the Fuel Pump was disconnected ad one of the pumps. The worm clamp seems to have been tight, but either it came off. I dont know what caused it to come loose and i did not want to take a chance on wether the pump was good or bad. So i just bought a new one and through it in there so that i wouldnt have to worry about. it was a tough job all by myself.
either the truck is happy again. Thanks for your help.
Old Jun 15, 2007 | 05:43 PM
JeffsLightning's Avatar
Did you put a metal Y fitting in?
Old Jun 15, 2007 | 09:45 PM
SWThomas's Avatar
You should've done a little upgrading while you were in there...
Old Jun 16, 2007 | 07:56 PM
tallimeca's Avatar
last spring
with an epidemic of fuel lines popping off, i decided to pull my bed and check the clamps. I decided if i was to go through all that, i'm upgrading the pumps and putting a metal y fitting in there.
It makes a difference with the new pumps. Fuel pressure guage moves alot quicker when you stomp it. It doesn't climb, it snaps right over.
