lower intake polishing?
Old Jun 12, 2007 | 12:42 AM
Klitch's Avatar
since the last thing i read was porting the lower intake manifold is moderately hard to do since there isnt much working room or material, would there be any marginal benefit from just polishing it up? i do have port n polished heads so i was kind of wondering about port matching?
what do you guys recommend? also, whats generally used for polishing consumables? i assume most use a dremel and some buffing wheel after its smoothed by a grinding stone? any special clays or something?
Old Jun 12, 2007 | 01:15 AM
Master Of Pain's Avatar
If you can get it jet-hot coated as well, you should see less heatsoak and quicker drop in IAT2.
Old Jun 12, 2007 | 08:26 AM
Klitch's Avatar
can you elaborate more on that? ive never heard of it.
Old Jun 12, 2007 | 09:15 AM
Dbl G's Avatar
Porting and polishing has it's benefits, you should find a local shop that has a flow bench and do it up right.
A Home "Port" will still work wonders, just go slow and blend things smoothly...
Old Jun 14, 2007 | 10:45 AM
SVTRobG's Avatar
Smile Ceremic coated intake...
http://www.jet-hot.com/
You can also check with any local powder coaters in your area as most of them do ceremic coatings as well.
Old Jun 14, 2007 | 04:05 PM
Dbl G's Avatar
Ceramic coating isn't really a good idea it will keep heat in, one would want the intake air cooler not hotter, same goes for chroming however to a lesser degree.
Old Jun 14, 2007 | 05:04 PM
Eds 01 Lightnin's Avatar
I had my egr tube ceramic coated and all I can say is it now stays cooler to the touch when the engine is HOT and seems to cool much quicker than before. No actual temps taken to prove my theory though.
I like the looks of that CC intake! Might have to do mine this winter. I should have done it when the SC was swapped and IC cleaned last winter!
Old Jun 14, 2007 | 06:07 PM
Dbl G's Avatar
It would be cooler to touch . it is containing the heat. this is why headers get coated, for increased heat scavenging. Ceramics will either contain or repel heat.
Old Jun 14, 2007 | 06:38 PM
Makes sence, G! BTW, did you ever get your lower polished as you had planned?
Old Jun 14, 2007 | 07:41 PM
Dbl G's Avatar
Not as of yet,, need some spare $$ first.
Old Jun 16, 2007 | 12:14 PM
Klitch's Avatar
as for polishing, any tips? i think the general consensus is to take it out to have it done (but moneys an issue now) or do minimal porting and make it blend well?
Old Jun 16, 2007 | 12:41 PM
Dbl G's Avatar
http://www.nhtoc.com/vbforum/showthr...=polishing+101
