These are BIG tires.
The wheel is a 17x10 Prime wheel with a tire height of ~31 inches. He has a blown 98 STX 4.6L that is pushing 260rwhp. Never had traction problems when his truck was stock. I think 31" is the stock tire height for his truck. He wanted to maintain the 4:10 gear ratio that was recently installed. Big tires and not that expensive.
Yep, those are my "Poor-man's" racing tires and I hope they will soon be listed in the Go-rila Racing Package. I think I might run them every day though. It depends how they look on the truck. My stock tire height is around 30 inches and these are around 32 inches which knocks my gear ratio down from 4:10 to about 3:90. Based on my dyno run this month, the tunner thought I might be geared too low for the 1/4 and that I would do better on a blown truck with a 3:73 gear ratio. Anyway, we will see!
98 White 4.6 Triton STX (It's not an STX anymore) Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Ground Force 2-4 Drop,Custom MB Phantom Wheels,clear corner lenses,monster battery terminals,MTX Sub Box with 2 10 inch Polk Subs, 4 Plok Speakers, MTX 102 Amp with Pioneer FH-P4400 CD Cassette Head Unit,Custom Programmed Super Chip,BBK 75mm TB, Pro M 80mm MAF,Pillar Pod w/ boost and trans temp,Jacobs DIS Ignition,Art Carr 2000-2400 stall transmission,4:10 gears,custom rear end housing, custom intake tube, Jet coated JBA stainless headers, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
http://www.zing.com/album/?id=4293450711
[This message has been edited by Flats Man (edited 01-14-2001).]
Sixpipes...The offset on your wheels look close to stock. What type of handling and ride do you get over stock? Are you running stock shock absorbers. I would consider a 20 tire and wheel combo....what is the outside diameter compared to what we have on these 1999-2001 Lightnings? thanks..
Later on..I was thinkin' about the Fiske FM5's in 20 inch. They custom makem...
Flats Man's answer to drag radials. Goodrich Sport Truck T/As in 345/55R17. They are pictured against my 295/40ZR20s.
[This message has been edited by sixpipes (edited 01-14-2001).]
