upper grill removal????
Old Jun 2, 2007 | 12:53 PM
SVTLIGHTING's Avatar
I am trying to take the upper grill off my truck. I got everything loose except for around the headlights. Are there any bolts or clips in there i am missing. Its driving me crazy.
Old Jun 2, 2007 | 05:35 PM
chucks bp's Avatar
With the hood open look behind the side marker lights you will see a seven mm bolt with a torx head, remove this bolt and slide the side marker light forward, after removing the light there will be two Phillips screws that retain the shell to the support this should free up the grill shell. There are also two clips in the center of the grill, you can reach behind the center grill opening and squeeze the clips to release. Here is a link that may help, http://www.streetsceneeq.com/instruc.../950-77703.pdf
Old Jun 3, 2007 | 01:30 AM
Thanks chuck.... Got it off. I figured it out eventually. What a pain in the a$$>
Old Jun 21, 2007 | 09:22 PM
Veteran: Army
thanks search option, lol
thanks for the link "chucksbp"
