Upper A-arm cam bolt kit P/N?
Old Jan 3, 2001 | 04:07 PM
Peter B's Avatar
Question Upper A-arm cam bolt kit P/N?
did a search and could not find anything about this, but I know its out there. Does anyone have either a TSB number or a part number for the upper A-arm cam bolt kit? Also is it something the dealer must install or can they give me one over the counter so I can install myself? What all is involved in the installation?
Old Jan 3, 2001 | 06:17 PM
LightStruck's Avatar
Post
Peter B. go here,
https://www.f150online.com/f150board...ML/007931.html
and read my reply in post (part of the way down)
Here's the TSB #14417 for the lower control arm clunk--covers toothed washers and nut. Is that what you needed?
Also check this link:
https://www.f150online.com/f150board...ML/008148.html
[This message has been edited by LightStruck (edited 01-03-2001).]
Old Jan 3, 2001 | 06:33 PM
gforce's Avatar
Post
Peter B.,
Yes, you can do it yourself. After all that movement on the upper suspension, have it aligned to get within specs. From there, have your brother help you "tweak" the alignment to get it perfect.
Black '00
#1,757 built 3/30/00
Clear corners
J.L. Single program
J.L. Stage II ram-air
Old Jan 3, 2001 | 07:42 PM
Ryan2KRedL's Avatar
Post
Under the Ford TSB the number lists as Article No. 00-25-08.
Says to torque nut to 190 N-m(140 lb-ft).
Site this came from is:
http://www.fordtechservice.com/tpsco...NI4/TY2508.HTM
Mine goes in this Friday for the fix. Will be happy to report my results after driving for a few days!
Good luck!
Ryan
  • 2000 Red Lightning
  • 13.13 @ 106.40 mph in 1/4 mile
  • 8.50 @ 85.43 mph in 1/8 mile (same run)
  • Superchip R9, Airaid box with S+B 10" filter
Old Jan 4, 2001 | 02:36 PM
alphadoggy's Avatar
Post
Specialty products http://www.specprod.com/ manufactures a cam bolt kit for the L. that is considerabley cheaper than the Ford kit. It lists for $62.50, but I got it for $44.29 + tax from a local distributor.
I'd rather have a bottle in front of me than a frontal lobotomy.
'84 Alan Record Carbonio, Aerospoke wheels, Campy brakes.
'00 SVT Lightning, silver, G-tech Pro, JBA headers, 4.10 gears, Swanson chip, Pro-M, NGK plugs, carbon drive shaft, Roadmaster suspension kit
13.39 @ 102.5
2001 Kevlacat 2400, twin 115 Evinrude FICHT, Raytheon VHF, radar, autopilot and GPS chartplotter/fishfinder.
gmvye@pacbell.net
Old Jan 4, 2001 | 02:56 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Question
Hey Alpha,
what is the part number from spec parts?
Thanks,
Robert
Old Jan 4, 2001 | 06:10 PM
AG Bolt's Avatar
Lightbulb
NAPA has a cam bolt kit that comes with the parts to do one side in one kit, (2 bolts, 4 cams,nuts and washers. Part no. 264-2953. Price was 17.82 list, but got mine at jobber
