dyno tuned
Old May 11, 2007 | 03:33 PM
mike martinez's Avatar
dyno tuned
hello out there, i have an 01 lightning with the following speed parts installed, one set crower stage III cams, 12lb boost lower pulley, 3inch cog belt drive,predator tuned, three inch eldebrock race mufflers, 4" k&n air intake system "cone" style., took my truck for dyno run and truck produced 342rwhp, and 631 ftlbs of torque however, neither they or i no how to figure how much crank hp i have, dyno my truck was run on is a i think they called it a chaasis dyno? can anyone help me to figure what my engines crank hp is? thanks mike.:
Old May 11, 2007 | 04:00 PM
LTNDave's Avatar
was the chasiss dyno a DYNOJET or a MUSTANG as this make a big difference as to what your number are.
BTW your numbers seem weird... you have an enourmous amount of torque for the amount horsepower.
for a rough calculation: figure that your drive train loss is somewhere in the 20% range through the trans/DS/ and axle, So
342*.20= 68.4...342+68.4= 410.40 CHP
631*.20=126.2...631+126.2= 757.20 CTQ
but those number do not seem to jive to me
do you have a built motor?
Old May 11, 2007 | 04:07 PM
01_White_Light's Avatar
Either the 342 was a typo or something is seriously wrong with that tune.
Now, is your lower pulley a 12# or are you seeing 12#'s of boost on your guage? With a 12# lower pully I'm surprised you didn't blow the motor. But, I'm betting you got a 4# lower pulley and even still your numbers would be different.
Old May 11, 2007 | 05:03 PM
Bird's Avatar
If they started the run at too low RPM and flashed the torque converter, it would explain the high torque numbers.
Bird
Old May 11, 2007 | 05:34 PM
Silver-Bolt's Avatar
A down shift during the pull would account for the weird numbers.
Old May 12, 2007 | 01:25 AM
LTNDave's Avatar
as would a pull in OD, not locked in 3rd
